You should use use the setup command to install Maya. There is no need to use command line parameters. If you want to do it, you can review this blog post:
Delete Maya the easy way....
Please not that the instructions are ideal if you do NOT have AutoCAD Mac and Smoke on the same computer as Maya. The adlmreg will basically take out the Maya entry from the .pit file. If you do NOT have AutoCAD or Smoke installed, it's safe to delete files/folders as noted above.
More info on Productinformation.pit file is noted here:
http://upandready.typepad.com/up_and_ready/2011/10/autocad-family-edu-and-commercial.html
If your licenses are standalone, check this out...
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
Why is it that Autodesk doesn't just wrap an uninstaller into the Maya app?
