Hi, I just Installed AutoCAD 2011 Student Edition and I can't use it. Installed as administrator, and running as admin. but I keep getting an error every time I try to run the program. (Unable to run AutoCAD. This may be due to one of the following reasons: 1.this version of AutoCAD was not installed properly 2. you do not have suffencient rights to fun AutoCAD). I'm running the same windows /CAD version as the college I attend and they have no problems what so ever. perhaps I messed something up? I checked the install log and noticed some "fails", here they are:
MSI (c) (A0:84) [21:46:58:312]: Failed to grab execution mutex. System error 258.
MSI (s) (B8:2C) [21:46:58:562]: APPCOMPAT: no matching ProductCode found in database.
But I got "success" on all parts of the install.
2011/9/6:21:25:52 Adam BONEYARD === Setup started on BONEYARD by Adam ===
2011/9/6:21:39:35 Adam BONEYARD Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2011/9/6:21:40:22 Adam BONEYARD Install Autodesk Design Review 2011 Succeeded
2011/9/6:21:43:11 Adam BONEYARD Install .NET Framework 2.0 SP2 Update KB958481 Succeeded
2011/9/6:21:43:48 Adam BONEYARD Install .NET Framework 3.0 SP2 Update KB958483 Succeeded
2011/9/6:21:44:21 Adam BONEYARD Install .NET Framework 3.5 SP1 Update KB958484 Succeeded
2011/9/6:21:44:43 Adam BONEYARD Install DirectX 9.0 Runtime Succeeded
2011/9/6:21:44:51 Adam BONEYARD Install FARO LS 1.1.406.58 Succeeded
2011/9/6:21:45:48 Adam BONEYARD Install Autodesk Material Library 2011 Succeeded
2011/9/6:21:46:54 Adam BONEYARD Install Autodesk Material Library 2011 Base Image library Succeeded 2011/9/6:21:49:41 Adam BONEYARD Install AutoCAD 2011 Succeeded
2011/9/6:21:57:44 Adam BONEYARD Install AutoCAD 2011 Language Pack Succeeded
2011/9/6:21:59:57 Adam BONEYARD Install Autodesk Material Library 2011 Medium Image library Succeeded 2011/9/6:22:03:53 Adam BONEYARD === Setup ended ===
I'm at a loss, if anyone could help it would be great, thanks.
Please try
Did you manage to fix the issue ?
I have the same problem but with AutoCAD P&ID 2011 running on Windows XP Professional SP3 32 bit.
Have you tried the suggested steps
Please post all the log files as a zip file identify the cause
Hi Sir,
This is the third time im having problem as mentioned below i Installed AutoCAD 2011Architecture STUDENT EDITION today and previously i installed AUTOCAD 2011 Student Edition and I can't use it. Installed as administrator, and running as admin. but I keep getting an error every time I try to run the program. (Unable to run AutoCAD. This may be due to one of the following reasons: 1.this version of AutoCAD was not installed properly 2. you do not have suffencient rights to fun AutoCAD).
I red the previous discussion and the NET. fix technique wont work on my operating system because im using windows XP so kindly help me get out of this problem its been waste of time untill now for me. waiting and downloading. Please i will be very gratefull to you.
Tariq.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Right click Autocad 2011 Icon/Properties/Advanced Button/Check in Run as Administrator
Now. You can open Autocad 2011
