style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I've
been testing the license check out utility but I can't return the license
early. I'm getting an error message saying "your license cannot be returned at
this time becuse you are unable to connect to the license server" I saw a post
back in May that suggested downloading the latest lmtools.exe. I did that, in
fact I grabbed version 9.2 of all three lm*.exe. I tried the suggestion of
renaming lmtools to lmborrow and overwriting the one on my station but it
hasn't worked. Has this been fixed or is there another solution to try?
Brian
"bstaples" <I
href="mailto:bstaples@freemanwhite.com">bstaples@freemanwhite.com>
wrote in message
href="news:f179d65.1@WebX.maYIadrTaRb">news:f179d65.1@WebX.maYIadrTaRb...
am using a LICPATH.LIC. I restored the original lm*.exe back to the way they
were but I am still getting an error. This time the error lists an error
[-17]. in the FLEMlm guide it says this number means "cannot write data to
license server" I know the server is up and running and lmtools is also up and
running- about half of my available licenses are currently in use. I checked
to make sure there was no environment variable by right-clicking my
computer-->properties-->advanced-->env variables. If it's not in
there will it be anywhere else? In the Help-->about section of lmtools.exe
on the server it says it's version 8.3c Is that the correct version?
Brian
"bstaples" <I
wrote in message
href="news:f179d65.3@WebX.maYIadrTaRb">news:f179d65.3@WebX.maYIadrTaRb...
am using the Autodesk Borrowing Utility installed on my station. If I go to
the server and try to take it back using lmtools it says error:
43200ARCHDESK_2004_0F not currently borrowed. If I go to server status and hit
display everything it says there is one licensed lingered and shows in the
debug log as me having it out, even with it not running. The lmborrow version
in my autodesk shared folder (under common files) is version 8.3.1.0
Brian
"bstaples" <Thanks,
wrote in message
href="news:f179d65.5@WebX.maYIadrTaRb">news:f179d65.5@WebX.maYIadrTaRb...
I didn't know that. Yes to the question. It tells me I have a borrowed license
set to expire August 1.
Brian
