Have been using A LT2005 upgrade from 2002 for the last few years. The upgrade was a downlload so I do not have the original CD, only the upgfrade.exe file I downloaded.
Now after installing LT2009 to use I was able to remove 2002 but the 2005 is giving me the error:
"The installation source for this product is not available. Verify that the source exists and that you can access it."
I have gone so far as to reinstall both 2002 and the 2005 verions and am still receiving the same error. The only other method I have been able to find that might be the answer is the one described here. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240817
Is there any other suggestions or methods that will not require removing and reinstalling the 2009 version?
