Hello, After un-installing Inventor 2012 I installed 2013 succesfully. My machine was getting full so I used the Autodesk uninstall tool to un-install some parts of the Premium Design Suite 2013 that I never use as I did with 2012.
(I really only need Inventor & Autocad)
Afterwards I got error messages when trying to open Inventor. I used both the Autodesk uninstall tool & add/remove programs in windows 7. Some parts will not un-install & each time I try to re-install the Premium Design Suite 2013 the checklist of programs to install shows a check on Inventor and states that it is already installed & will not reinstall.
I have deleted all related folders on C drive as well as attemping to remove any registry entries I can find that Im sure are related. Below is a list of remnants still appearing in the windows 7 add/remove programs, this is the only place they remain as everything is gone from start/all programs etc. Any help would be greatly appreciated.
1) Autodesk Backburner 2013.0
2) Autodesk Sync
3) Autodesk Fusion
Paul
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
