Installation & Licensing
New Member
oldshackdesign
Message 1 of 4 (519 Views)
Unable to launch AutoCAD application after hardware change
519 Views, 3 Replies
06-03-2013 09:57 AM
Hello, I have the same problem described above. My laptop screen broke, so my hard drive with my original installation was put into a desktop machine. I've repaired, reinstalled, uninstalled, and reintalled three times now - still no luck. I can't reactivate my license because the software crashes (without an error message) before going to the activation screen. How do i solve this probelm?
Thanks, Mary
Discussion_Admin
*Expert Elite*
rkmcswain
Message 2 of 4 (510 Views)
Re: Unable to launch AutoCAD application after hardware change
06-03-2013 11:04 AM in reply to: oldshackdesign
Thanks, Mary
Uninstall, then do a complete wipe of all Autodesk software off the machine as described in the KB article here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240697
Then reinstall.
*Expert Elite*
nestly2
Message 3 of 4 (502 Views)
06-03-2013 11:24 AM in reply to: rkmcswain
The nuclear option posted by RK may be your best bet due to the hardware changes, but you may also try resetting the license manager.  The fix below solved my issue where AutoCAD would flash the splash screen, then immediately close with no error messages.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15890817&linkID=9240617
*Expert Elite*
rkmcswain
Message 4 of 4 (497 Views)
06-03-2013 11:50 AM in reply to: nestly2
Good idea. Hopefully the OP will post back letting us know if that worked!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
