Installation & Licensing
Unable to install Autodesk Revit Architecture 2012
1 REPLY 1
JNLHD77
254 Views, 1 Reply
I donwloaded the AutoDesk Revit Architecture 2012 for Students and received a license key but everytime I try to install it goes through the process and tells me the installation is complete but some products failed to install.  In this case all products.
Please see the setup log and screenshot below.
Can you assist?
1 REPLY 1
TravisNave
in reply to: JNLHD77
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
Install	Microsoft Visual C++ 2010 Redistributable (x86)	Failed	Installation aborted, Result=1603
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
