Installation & Licensing
Active Contributor
m.latz
Message 11 of 13 (424 Views)
Re: Unable to install Autodesk Design Review 2012
08-30-2013 07:35 AM in reply to: toddw.schuler
Before the Design Review 2012 installer starts the installation the "install conditions" were checked. What you can do is add the required keys to the registry so that the installer thinks the runtimes were installed.
You can create a .reg file to add the necesarry entries.
Remember that the ADR installer is a 32-bit installer, so all entries are for 32-bit.
Markus
Active Contributor
toddw.schuler
Message 12 of 13 (420 Views)
08-30-2013 07:41 AM in reply to: toddw.schuler
Thanks, that sounds like a good option, what is the best way to determine the required keys?
Todd S.
Design and Drafting Supervisor
Energizer Battery Manufacturing
Phone 440-835-7876
________________________________
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you are not the named addressee you should not disseminate, distribute, retain, or copy this e-mail or any attachments. If you have received this email in error please delete and notify the sender.
Active Contributor
m.latz
Message 13 of 13 (413 Views)
08-30-2013 09:30 AM in reply to: toddw.schuler
If you try to install with setup.exe you see in the log files which VC runtime fails. And if you are sure, that you have i.e. a higher VC2008 runtime installed, then you can temporarily add one of the keys to the registry.
Then this check during the installation process is TRUE
On the screen shot the right column says for which runtime the regkey is.
You can send me your install log file from the %temp% folder, than I can take a look.
regards
Markus
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
