Installation & Licensing
Member
Message 1 of 52 (24,349 Views)
Accepted Solution
Unable to activate Maya 2014 error 110
24349 Views, 51 Replies
10-13-2013 09:54 AM
hello everyone
i have just upgraded to maya 2014 and im unable to activate it.
Installation runs without any problems then when i start maya i see the activation screen and as soon as i click activation i receive a licensing error code 110
when i click ok i get this dump
License was not obtained
Tried Maya 2014 (657F1 2014.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
i am using Osx 10.9
Product Support
aaronhai
Message 2 of 52 (24,326 Views)
Re: Unable to activate Maya 2014 error 110
10-13-2013 10:34 PM in reply to: ohad111
Hi ohad111,
Welcome to Autodesk Discussion group.
Based on the error code, it appears to be license information file problem. Let's try to re-initialized license information and un-installing Maya:
To uninstall Maya on Mac OS X
1. Navigate to the Maya directory (by default, /Applications/Autodesk/Maya2014/).
2. Drag the Maya2014 application to the trash.
Re-initialized license information
1. Open a Terminal window and execute both of the following commands, where <productKey> is your product key:
adlmreg –u S <productKey> 2014.0.0.F
2. This ensures that product information is properly removed from the ProductInformation.pit file.
3. You should be prompted to re-activate product.
Let us know if that works. Thank you.
Aaron Hai
Member
Message 3 of 52 (24,263 Views)
10-15-2013 10:02 AM in reply to: ohad111
its not working
when i try to run the terminal command i receive the following error:
Invalid number of arguments.
-usage: ./adlmreg -i N 657D1 ***** 2011.0.0.F 000-00000000 /Library/Application Support/Autodesk/Adlm/PIT/MayaConfig.pit
       ./adlmreg -u N ***** 2011.0.0.F
after closer inspection it seems that the path /Library/Application Support/Autodesk/ doesn't exist and reinstalling doesn't create this folder.
Member
Message 4 of 52 (24,187 Views)
10-18-2013 09:25 AM in reply to: ohad111
Is there anyway to contact autodesk support directly.
if i can't get it to work i can't get my assignments done
Product Support
Message 5 of 52 (24,118 Views)
10-21-2013 07:47 AM in reply to: ohad111
Follow these steps exactly.  This will hopefully get you to request an activation.
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
If you are using Parallels, check out this post:
http://upandready.typepad.com/up_and_ready/2013/03/parallels-fusion-boot-camp-autodesk-products.html
It's best to use Boot Camp for best performance.
Redownload Maya 2014 SP 1 here and re-instal it using your EDU serial number and product key.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21899403&linkID=9242259
David Lau
Member
Message 6 of 52 (23,989 Views)
10-23-2013 08:17 AM in reply to: ohad111
Running into the same error after doing a fresh install of Mavericks yesterday.  If you look at the os x console when openeing maya 2014 you will see this...
10/23/13 11:16:36.295 AM LMU[5580]: 5580 Execing /Applications/Autodesk/Adlm/R7/LMU.app/Contents/MacOS/lmuopen
10/23/13 11:16:36.295 AM LMU[5580]: 5580 with argument: lmuopen
10/23/13 11:16:36.295 AM LMU[5580]: 5580 with argument: /Applications/Autodesk/Adlm/R7/LMU.app/Contents/MacOS/LMU
10/23/13 11:16:36.324 AM lmuopen[5580]: Launching: /Applications/Autodesk/Adlm/R7/LMU.app/Contents/MacOS/LMU
10/23/13 11:16:37.464 AM universalAccessAuthWarn[3424]: AccessibilityAPI: pid 5575, is not allowed to access the accessibility API. Path: /Applications/Autodesk/maya2014/Maya.app/Contents/MacOS/Maya (Leaf request from pid 5581 Path: /Applications/Autodesk/Adlm/R7/LMU.app/Contents/MacOS/LMU)
10/23/13 11:17:01.275 AM Maya[5575]: modalSession has been exited prematurely - check for a reentrant call to endModalSession:
10/23/13 11:17:01.288 AM com.apple.launchd.peruser.501[187]: (com.autodesk.Maya.2014.79232[5575]) Exited with code: 251
Looks like something changed in 10.9 that is blocking the Maya licensing....
Please updae ASAP Autodesk
Product Support
Message 7 of 52 (23,984 Views)
10-23-2013 08:26 AM in reply to: xeno3d
Member
Message 8 of 52 (23,979 Views)
10-23-2013 08:32 AM in reply to: david.lau
Interesting, though not a viable option at the moment.  Is there a fix coming soon?
Member
Message 9 of 52 (23,947 Views)
10-23-2013 11:45 AM in reply to: xeno3d
Well that was fast.  Maya 2014 SP3 works like a charm.  Thanks Autodesk!
New Member
Message 10 of 52 (23,884 Views)
10-23-2013 05:02 PM in reply to: ohad111
I'm having this issue on my Macbook Pro with Maya 2014 Student edition and can't seem to fix this. Everytime I click activate in the Licensing Window it  displays an error message reading:
A license error has occurced. Contact your technical support representative for assistance
To  help determine the nature of the problem, the error code is : 110
Any ideas?
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
