Installation & Licensing
Unable to Reinstall Civil 3d 2014
3 REPLIES 3
sdecker
345 Views, 3 Replies
Tried to install Civil 3d 2014 and it hung and I had to cancel it as it had not moved in an hour.  Tried to run a reinstall, that failed.  Tried the help document here and am now receiving the attached errors saying autodesk is still installed, but cannot install as autodesk is not installed.
3 REPLIES 3
TravisNave
in reply to: sdecker
Welcome to the community!
I apologize for your inconvenience.  You installation was probably not hung, it just likely required additional downloading from Autodesk servers.  In some instances, I have seen programs like this and Revit take in upwards of 8 hours to complete.  You simply need to be patient.  I recommend installing overnight in this instance -- especially if you have a slow Internet connection.
Cancelling an install can cause a major headache on subsequent installs or uninstalls.  But they too can be fixed.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
I hope this helps!
Autodesk Forums:
sdecker
in reply to: TravisNave
Just wanted to say that downloading the offline Program Install and Uninstall from MS was the key. It was able to remove traces of 2014 and I was able to reinstall everything without issue.
TravisNave
Excellent.  Thanks for the verification.  It will certainly help others who are seeking answers for the same problem.  I am glad you are up and running.
Autodesk Forums:
Administrator Productivity
