• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Expert Elite*
    Neilw
    Unable to Re-install Civil 3D 2013
    142 Views, 6 Replies
    09-04-2012 01:31 PM
    I was running Infrastructure Suite 2013 and started crashing after installing and uninstalling some Antivirus demos. I have uninstalled all the applications that were installed by the suite and now when I attempt to re-install, the installer reports that Autocad 2013 and Map 2013 are already installed. I have filed a support case (CaseNo:07546800) and have followed all the recommendations provided yet I am still unable to re-install.
    My first report on this issue was on 8/14/2012 (CaseNo:07539559). Thus I have been unable to use my software for close to 1 month. It seems my communications with support are not getting through so I am feeling pretty frustrated and helpless. Could someone please look in to this?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Unable to Re-install Civil 3D 2013
    09-04-2012 01:43 PM in reply to: Neilw
    To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
    http://support.microsoft.com/mats/Program_Install_and_Uninstall
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    Neilw
    09-04-2012 01:51 PM in reply to: TravisNave
    Travis,
    I have followed all the instructions and tried all the utilities in the links you posted.
    I've never encountered a problem like this with any software. There really needs to be a utility to address this or the product installer should be re-worked.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    TravisNave
    09-04-2012 01:54 PM in reply to: Neilw
    Well then you're missing something registered somewhere then.  In all my years, I've never seen these not work.
    Travis Nave
    *Expert Elite*
    Neilw
    09-04-2012 01:59 PM in reply to: TravisNave
    I was hoping to have a remote session with support but I haven't been able to get one set up.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    *Expert Elite*
    DarrenP
    09-04-2012 02:06 PM in reply to: Neilw
    do you have CCleaner installed?
    if you do try running that
    *Expert Elite*
    Neilw
    09-04-2012 02:12 PM in reply to: DarrenP
    I have run RegCleaner and REVO and others besides the utilities that were in the posted links. I haven't tried CCleaner. I've already spent a lot of time on this so I've put it into the hands of support. They need to follow through.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
