CWurz said the following on 4/4/2006 9:05 AM:
> I have created a network deployment through the deployment wizard for Land Desktop Companion to Civil 3d. Everything works fine except I had a file path under the Client Support Directory Location put my chosen path, but then it adds the default path in front of it?
> This is how it reads : C:\Documents and Settings\All Users\Application Data\G:\CAD Library\LDDT Support\Data\
> The G:\... is the path I want.
> I try to modify the deployment by deleting the C:\Documents and Settings\All Users\Application Data\ and then go through the rest of the deployment and save. It says it is saving and updating the deployment, but every time I go into the deployment it is maintaining the entire path with both locations??
> What am I missing??
> Is there a patch out there that I can not find that will resolve this?
> I can run the deployments without being silent and change this for every machine, but I should just be able to modify the deployment and get it to work that way.
> Any help would be greatly appreciated.
> Chad
You might search this group and/or AUGI, but I think I remember reading
this was a bug in the deployment wizard.
We post-process the standard deployment, so I have not run into this issuse.
R.K. McSwain
http://rkmcswain.blogspot.com
