Installation & Licensing
Active Member
pscheu
Message 1 of 34 (8,237 Views)
Unable to Install ACAD 2012
8237 Views, 33 Replies
03-30-2011 10:11 AM
As I attempt to install a stand alone copy of ACAD 2012 for 64 bit on a single machine from the DVD disc, I get an "Internal Error 2723" message at "step 5 of 7" and the installation aborts. I do get past entering the serial number and product key, so that's not an issue. Running Vista Business 64 bit SP2. I've attached the Setup log for reference. Any insights would be appreciated. Thanks.
TravisNave
Message 2 of 34 (8,233 Views)
Re: Unable to Install ACAD 2012
03-30-2011 10:16 AM in reply to: pscheu
Copy the disc to your hard drive and install from there and see if you get the same error.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
DarrenP
Message 3 of 34 (8,232 Views)
03-30-2011 10:18 AM in reply to: pscheu
Active Member
pscheu
Message 4 of 34 (8,222 Views)
03-30-2011 11:24 AM in reply to: pscheu
Thanks TravisNave and DarrenP. Unfortunately I tried both (installing .NET 4 first then trying the installation from the hard drive), but got the same result (Internal Error 2738). Pretty frustrating.
Valued Mentor
frhervet
Message 5 of 34 (8,189 Views)
03-31-2011 02:25 AM in reply to: pscheu
see this :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9243099&id=7289987&siteID=123112
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
Active Member
pscheu
Message 6 of 34 (8,186 Views)
03-31-2011 03:01 AM in reply to: pscheu
Thanks. The page you directed me to is for Revit, and the link from there to the Windows Script is for Windows XP. My issue is with AutoCAD 2012 with Vista Business 64 Bit. I tried the propsed solution anyway, but it the script would not load - I assume beause the OS is different.
BTW - Autodesk'sSubscrition Support suggested I perform a clean install per http://usa.autodesk.com/getdoc/id=TS75218 with most Windows services turned off (essentially in Vista's equivalent of "Safe Mode"), and that didn't work either. In fact, during the clean install, a Windows dialog box came up indicating that there was a file was in use and should be closed. That “file” was Windows Explorer, which I assume is a pretty basic service. I tried both options presented by the dialog box – close the file and continue, or not closing the file where a reboot would have been required. The result was the same in both cases – “Error 2738” occurred, and the installation aborted at “Step 5 of 7”.
Grrrrrrr.....
TravisNave
Message 7 of 34 (8,166 Views)
03-31-2011 07:48 AM in reply to: pscheu
Maybe you have a bad disc?  Could try the download version and see if it is any different with the results.
New Member
FranzPlötzl8918
Message 8 of 34 (8,152 Views)
03-31-2011 11:53 AM in reply to: pscheu
we also can not install autocad architekt 2012 win7x64 - error 2738.
we also tried to install the net4framwork before installing acad - same error.
on an second computer - win7x64 - the same problems.
TravisNave
Message 9 of 34 (8,146 Views)
03-31-2011 01:12 PM in reply to: FranzPlötzl8918
Then the problem is specific to the configuration of that machine.
This error 2738 indicates a custom action is trying to run on a system, but that it is unable to execute script code. For one reason or another the scripting service is not running correctly and thus the install is failing. To possibly resolve this, download and install the latest Windows Scripting Host release available at MSDN online.
Active Member
pscheu
Message 10 of 34 (8,140 Views)
03-31-2011 01:24 PM in reply to: pscheu
Thanks, TravisNave. Tried that, and it didn't work either. Still haven't heard back from AutoDesk...
