Installation & Licensing
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Morton, Simon
URGENT PROBLEM
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
82 Views, 1 Replies
11-09-1999 08:03 AM
We have a R14.01 NLM runningon Novell 4,12 Server, this has been working
fine for 12months. However at weekend we renamed the Novell Server. Thus we
had to apply for new Auth Codes. The new codes went in fine and it released
5 licences.
However the Windows 95 workstations running AutoCAD cannot pick up a
licence. We have added the line SET ACADSERVER=servername to the
Autoexec.BAT, no joy............. The workstations were never touched, so
nothings changed.
Any suggestions will be greatly appreciated,
regards
Simon Morton
5 licences.
nothings changed.
regards
Simon Morton
*Milana, Jerry
Re: URGENT PROBLEM
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
11-10-1999 11:44 AM in reply to:
*Morton, Simon
Simon,
The first thing to do is take a look at your adlm.log file. It will be in the
\adlm\log directory on your server. First check to see if any activity has
been logged from the workstations, if there has, it is likely to give you an
error message pointing you towards the problem. Also scan the log file looking
for keywords failure and invalid and valid. these words may lead you to a line
in the log file where a problem can be spotted.
While you have the log file open, look for a line that looks like this:
99-Sep-08 14:39:48: ADSKELMD.NLM 5.0.1f started on PARADISE (82cbcf97.000001).
In this case, the server name is PARADISE. This value is case sensitive and
the ACADSERVER variable must be set exactly the way the server name appears
here. It is also a common mistake to enter the server name in the wrong case
when generating a server code in AdLM Admin in the Add Hosts field. If this
happens, a server code will be generated however any authorization codes
generated based on this server code will be accepted by AdLM Admin but later
fail authentication when AdLM compares the authorization to the server's
properties.
Jerry Milana,
Autodesk Product Support
> 5 licences.
> nothings changed.
> regards
> Simon Morton
properties.
Jerry Milana,
> 5 licences.
> nothings changed.
> regards
> Simon Morton
