• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Morton, Simon
    URGENT PROBLEM
    83 Views, 1 Replies
    11-09-1999 08:03 AM
    We have a R14.01 NLM runningon Novell 4,12 Server, this has been working
    fine for 12months. However at weekend we renamed the Novell Server. Thus we
    had to apply for new Auth Codes. The new codes went in fine and it released
    5 licences.
    However the Windows 95 workstations running AutoCAD cannot pick up a
    licence. We have added the line SET ACADSERVER=servername to the
    Autoexec.BAT, no joy............. The workstations were never touched, so
    nothings changed.
    Any suggestions will be greatly appreciated,
    regards
    Simon Morton
    Please use plain text.
    *Milana, Jerry
    Re: URGENT PROBLEM
    11-10-1999 11:44 AM in reply to: *Morton, Simon
    Simon,
    The first thing to do is take a look at your adlm.log file. It will be in the
    \adlm\log directory on your server. First check to see if any activity has
    been logged from the workstations, if there has, it is likely to give you an
    error message pointing you towards the problem. Also scan the log file looking
    for keywords failure and invalid and valid. these words may lead you to a line
    in the log file where a problem can be spotted.
    While you have the log file open, look for a line that looks like this:
    99-Sep-08 14:39:48: ADSKELMD.NLM 5.0.1f started on PARADISE (82cbcf97.000001).
    In this case, the server name is PARADISE. This value is case sensitive and
    the ACADSERVER variable must be set exactly the way the server name appears
    here. It is also a common mistake to enter the server name in the wrong case
    when generating a server code in AdLM Admin in the Add Hosts field. If this
    happens, a server code will be generated however any authorization codes
    generated based on this server code will be accepted by AdLM Admin but later
    fail authentication when AdLM compares the authorization to the server's
    properties.
    Jerry Milana,
    Autodesk Product Support
    > 5 licences.
    > nothings changed.
    > regards
    > Simon Morton
