Are you only managing Autodesk licenses or are you also managing other
vendor's licenses too? If you are only controlling Autodesk licenses then I
recommend that you migrate all licenses to the new version of FLEXlm. If
you are controlling other vendor's licenses too then it may be desirable to
run both versions of FLEXlm. In the later case you will need to assign
ports to each instance of FLEXlm (lmgrd). If you get this wrong nothing may
work so carefully read the HTML documents that get installed to your FLEXlm
server folder or enlist some experienced help.
Jerry Milana,
Autodesk Consulting
wrote in message news:4811930@discussion.autodesk.com...
>I have received my AutoCAD 2006 with FLEXlm 10.1.5 and would like to
>install the new FLEXlm while keeping the old one around for a while. I
>have about 5 other software packages using the old version 9.2 FLEXlm and
>want to transition them over in an orderly fashion.
> The installation guide implies that you can have two versions running (on
> p. 25 it says, "If you choose a different installation folder, you will
> have two versions of the Network License Manager on the computer).
> Has anyone done it this way and had success?
> Thanks,
> Jay
