Installation & Licensing
Trying to remove MEP 2009
3 REPLIES 3
377 Views, 3 Replies
I am trying to remove MEP 2009 and keep getting an error message. See attached Doc.
Running x64 Windows XP Pro
3 REPLIES 3
TravisNave
Use the Microsoft Installer Clean-up Utility from Microsoft. Use this to remove MEP 2009 from your system. Then you can safely delete the application folder from Program Files.
Autodesk Forums:
Worked like a charm.
TravisNave
Awesome!
Autodesk Forums:
Administrator Productivity
