When trying to install, the only box able to check is Design Review. Why are the other 2 boxes greyed out? One of the greyed out boxes is REVIT Architecture 2011.
Solved by Chris.Aquino. Go to Solution.
Do you already have Revit installed or perhaps a trial version on your computer already?
There is a previous version of Revit but shouldn't it be removed when the new version is installed?
An older version shouldn't affect the new install. You might double-check that you don't have a 2011 version installed already. Check your add/remove programs to make sure.
We've seen two things cause the boxes to be grayed out at the product install screen.
1) You don't have Internet Explorer 7 or higher installed.
2) You have DWF Viewer installed.
Verify you have IE 7 or higher installed and DWF Viewer uninstalled.
