Installation & Licensing
Trying to install Autocad LT 2014 - continuously initializing
3 REPLIES 3
tbrainey
252 Views, 3 Replies
I am trying to install LT 2014 from disc. When I put the disc in, all it does is initialize continuously - I never even get to the point where I can hit the "Install" button on the first window. I have disabled or uninstalled all antivirus programs and checked to make sure I have the correct system requirements. I need to get this installed today. Please help.
3 REPLIES 3
pendean
in reply to: tbrainey
Bad disk or bad drive: why don't you just download it to install? No one is going to get you a new disk or drive today.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Education&st...
tbrainey
in reply to: pendean
I'm virtually useless where IT issues are concerned. I purchased LT 2014. Where and how can I download the software? Specifics are greatly appreciated.
TravisNave
Dean is right.  Downloading it would be the best bet.  But you could also try to just copy the disc to a folder on your hard drive and install straight from there too.
You can download your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
