Hi all hope u can help.
I am trying to install Inventor Suite 2011
I get error code.....
The installation cannot continue. The install source files are located on a path which is longer than 70 characters. Please locate the install source files in a folder with a shorter path.
I have no idea what its talking about...
please help!!
Please copy the installation source to the local disk
e.g:-c:\Autodesk
this should avoid any installation path errors
Hi could you please explain further.
I downloaded the 3 parts from the autodesk site. Would i need to extract all 3 parts???
When i tried to extract the second part the system advised me that these files already exist.
Thanks for your time
kev.
The first part will auto-extract all the remaining parts. Extract to the default location and then run setup. You should be fine.
