Installation & Licensing
Trueview 2012 silent install with no restarts
1 REPLY 1
Matt_B111
9129 Views, 1 Reply
We are trying to create a silent install for Trueview 2012 that doesn't restart the machine.
The machines are WinXP SP3 without Directx installed.  I have tried the following command but it forces a restart without any warning :
setup.exe /w /t /q setup.ini /Lang en-US
The install works ok, but we want to suppress the restart so that the user doesn't loose data etc.
Also, we are planning to use this with SCCM if that makes any difference.
Tags (1)
1 REPLY 1
hashim.mundol
in reply to: Matt_B111
Hi
Silent Directx Installation on Windows Xp is a known issue which doesn't have any official fix from Autodesk
http://docs.autodesk.com/MAP/2012/ENU/filesReadme/GUID-19FA7121-C7F6-439A-9648-17AA124F112-2.htm
But there are some discussions in the forum regarding this issue.
to summarise, if you can install directx with "dxsetup /silent" then restart the machine, trueview installation should go without a restart (on Windows XP).
http://forums.autodesk.com/t5/DWG-TrueView/TrueView-2011-deployment-via-SCCM-2007/td-p/2952066
http://www.msfn.org/board/topic/24909-directx-9c-silent-installation/
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Administrator Productivity
