Installation & Licensing
andrenext
Message 1 of 4 (5,121 Views)
Trouble reinstalling acad 2012. Inventor Fusion already installed?
5121 Views, 3 Replies
08-06-2011 10:29 PM
Sometime ago I went in trouble when unistalling Autocad 2012 architecture. Since then, when I reinstalled it, the Inventor Fusion option always shows as already installed, which is not true. I don't know how to fix it. I already tried to fix using MS Msi Cleanup Utility, but no "inventor fusion" appears there. Add/or remove program doesn't show inventor also. CCleaner doesn't help, or any other register cleaner (I think iobit toolbox register cleaner was causing some damage on Acad, because I had some problems to open/save as/import files, after used it)
If I try to uninstall/reinstall using directly the inventor fusion package from acad Dvd (x64/inventor fusion folder), it shows the message below:
Erro ao aplicar transformações. Verifique se os caminhos de transformação especificados são válidos.
in english: "Error applying transforms. Verify that the specified transform paths are valid."
I'm using Windows 7 Premium x64
=== Verbose logging started: 06/08/2011 23:50:32 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Windows\system32\msiexec.exe === MSI (c) (E0:44) [23:50:32:306]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg MSI (c) (E0:44) [23:50:32:306]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg MSI (c) (E0:04) [23:50:32:319]: Resetting cached policy values MSI (c) (E0:04) [23:50:32:319]: Machine policy value 'Debug' is 0 MSI (c) (E0:04) [23:50:32:319]: ******* RunEngine: ******* Product: j:\x64\inventorfusion\inventorfusion.msi ******* Action: ******* CommandLine: ********** MSI (c) (E0:04) [23:50:32:357]: Machine policy value 'DisableUserInstalls' is 0 MSI (c) (E0:04) [23:50:32:385]: Warning: Local cached package 'C:\Windows\Installer\14c0f5.msi' is missing. MSI (c) (E0:04) [23:50:32:393]: User policy value 'SearchOrder' is 'nmu' MSI (c) (E0:04) [23:50:32:393]: User policy value 'DisableMedia' is 0 MSI (c) (E0:04) [23:50:32:393]: Machine policy value 'AllowLockdownMedia' is 1 MSI (c) (E0:04) [23:50:32:393]: SOURCEMGMT: Looking for sourcelist for product {FFF5619F-6669-4EC5-A85E-9994F70A9E5D} MSI (c) (E0:04) [23:50:32:394]: SOURCEMGMT: Adding {FFF5619F-6669-4EC5-A85E-9994F70A9E5D}; to potential sourcelist list (pcode;disk;relpath). MSI (c) (E0:04) [23:50:32:402]: SOURCEMGMT: Now checking product {FFF5619F-6669-4EC5-A85E-9994F70A9E5D} MSI (c) (E0:04) [23:50:32:402]: SOURCEMGMT: Attempting to use LastUsedSource from source list. MSI (c) (E0:04) [23:50:32:414]: SOURCEMGMT: Trying media source J:\x64\InventorFusion\. MSI (c) (E0:04) [23:50:32:491]: Cloaking enabled. MSI (c) (E0:04) [23:50:32:491]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (E0:04) [23:50:32:508]: Connected to service. MSI (c) (E0:04) [23:50:32:511]: SOURCEMGMT: Resolved source to: 'J:\x64\InventorFusion\' MSI (c) (E0:04) [23:50:32:552]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'j:\x64\inventorfusion\inventorfusion.msi' against software restriction policy MSI (c) (E0:04) [23:50:32:578]: Note: 1: 2262 2: DigitalSignature 3: -2147287038 MSI (c) (E0:04) [23:50:32:578]: SOFTWARE RESTRICTION POLICY: j:\x64\inventorfusion\inventorfusion.msi is not digitally signed MSI (c) (E0:04) [23:50:32:581]: SOFTWARE RESTRICTION POLICY: j:\x64\inventorfusion\inventorfusion.msi is permitted to run at the 'unrestricted' authorization level. MSI (c) (E0:04) [23:50:32:585]: Cloaking enabled. MSI (c) (E0:04) [23:50:32:585]: Attempting to enable all disabled privileges before calling Install on Server MSI (c) (E0:04) [23:50:32:585]: End dialog not enabled MSI (c) (E0:04) [23:50:32:585]: Original package ==> J:\x64\InventorFusion\InventorFusion.msi MSI (c) (E0:04) [23:50:32:585]: Package we're running from ==> C:\Users\andre\AppData\Local\Temp\db6654.msi MSI (c) (E0:04) [23:50:32:591]: APPCOMPAT: Uninstall Flags override found. MSI (c) (E0:04) [23:50:32:591]: APPCOMPAT: Uninstall VersionNT override found. MSI (c) (E0:04) [23:50:32:591]: APPCOMPAT: Uninstall ServicePackLevel override found. MSI (c) (E0:04) [23:50:32:598]: APPCOMPAT: looking for appcompat database entry with ProductCode '{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}'. MSI (c) (E0:04) [23:50:32:605]: APPCOMPAT: no matching ProductCode found in database. MSI (c) (E0:04) [23:50:32:621]: MSCOREE not loaded loading copy from system32 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'DisablePatch' is 0 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'AllowLockdownPatch' is 0 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'DisableLUAPatching' is 0 MSI (c) (E0:04) [23:50:32:639]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI (c) (E0:04) [23:50:32:641]: Looking for file transform: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst MSI (c) (E0:04) [23:50:32:642]: Unable to create a temp copy of transform 'C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst'. MSI (c) (E0:04) [23:50:32:642]: Note: 1: 2203 2: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst 3: -2147287037 MSI (c) (E0:04) [23:50:32:642]: Couldn't find cached transform C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst. Looking for it at the source. MSI (c) (E0:04) [23:50:32:642]: Resolving source. MSI (c) (E0:04) [23:50:32:642]: Resolving source to launched-from source. MSI (c) (E0:04) [23:50:32:642]: Setting launched-from source as last-used. MSI (c) (E0:04) [23:50:32:642]: SOURCEDIR ==> J:\x64\InventorFusion\ MSI (c) (E0:04) [23:50:32:642]: SOURCEDIR product ==> {FFF5619F-6669-4EC5-A85E-9994F70A9E5D} MSI (c) (E0:04) [23:50:32:642]: Looking for file transform: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst MSI (c) (E0:04) [23:50:32:642]: Unable to create a temp copy of transform 'C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst'. MSI (c) (E0:04) [23:50:32:643]: Note: 1: 2203 2: C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst 3: -2147287037 MSI (c) (E0:04) [23:50:32:643]: Couldn't find cached transform C:\Windows\Installer\{FFF5619F-6669-4EC5-A85E-9994F70A9E5D}\InventorFusion.mst. Looking for it at the source. MSI (c) (E0:04) [23:50:32:643]: Looking for file transform: J:\x64\InventorFusion\InventorFusion.mst MSI (c) (E0:04) [23:50:32:643]: Unable to create a temp copy of transform 'J:\x64\InventorFusion\InventorFusion.mst'. MSI (c) (E0:04) [23:50:32:643]: Note: 1: 2203 2: J:\x64\InventorFusion\InventorFusion.mst 3: -2147287038 DEBUG: Error 2203: Database: J:\x64\InventorFusion\InventorFusion.mst. Cannot open database file. System error -2147287038 1: 2203 2: J:\x64\InventorFusion\InventorFusion.mst 3: -2147287038 Erro ao aplicar plataformas. Verifique se os caminhos de transformação especificados são válidos. J:\x64\InventorFusion\InventorFusion.mst MSI (c) (E0:04) [23:50:32:650]: Note: 1: 1708 MSI (c) (E0:04) [23:50:32:650]: Product: Autodesk Inventor Fusion 2012 -- Installation failed. MSI (c) (E0:04) [23:50:32:651]: Windows Installer installed the product. Product Name: Autodesk Inventor Fusion 2012. Product Version: 1.0.0.79. Product Language: 1033. Manufacturer: Autodesk, Inc.. Installation success or error status: 1624. MSI (c) (E0:04) [23:50:32:655]: MainEngineThread is returning 1624 === Verbose logging stopped: 06/08/2011 23:50:32 ===
Darin.Green
Message 2 of 4 (5,107 Views)
Re: Trouble reinstalling acad 2012. Inventor Fusion already installed?
08-07-2011 10:53 AM in reply to: andrenext
Andre,
Do you have other Autodesk applications on your machine?
I think the best solution for this type of issue is to perform a clean install of your Autodesk applications.
Use the following link to guide you through this process:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240697
After this, you should be able to install ACAD and InvFusion
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
andrenext
Message 3 of 4 (5,098 Views)
08-07-2011 09:25 PM in reply to: Darin.Green
Okay, I uninstalled all, deleted any folders related with autodesk, and other files and registry entries. It worked fine here. Thanx
Darin.Green
Message 4 of 4 (5,090 Views)
08-08-2011 06:39 AM in reply to: andrenext
You're welcome!
Darin Green
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
