I'm trying to install Invetor 2012 on a new machine and I have come across a weird issue. Installation goes smoothly until about the 3rd component, then stops with a 'Failed' message and the following log(truncated to the relevant part):
2012/11/5:09:09:53 ELa118 ELa118cat === Setup started on ELa118cat by ELa118 ===
2012/11/5:09:09:53 ELa118 ELa118cat Launch
2012/11/5:09:10:21 ELa118 ELa118cat === Setup ended ===
2012/11/5:09:09:55 ELa118 ELa118cat === Setup started on ELa118cat by ELa118 ===
2012/11/5:09:09:55 ELa118 ELa118cat Launch
2012/11/5:09:10:02 ELa118 ELa118cat Inventorui== Parameter: Prereq_1 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/5:09:10:02 ELa118 ELa118cat Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/5:09:10:02 ELa118 ELa118cat Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/5:09:10:20 ELa118 ELa118cat Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/11/5:09:10:20 ELa118 ELa118cat PageOpen LaunchDialog
2012/11/5:09:10:24 ELa118 ELa118cat Your computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.Please update .NET Framework 4.0 and restart your computer before installing your
Autodesk product.2012/11/5:09:10:33 ELa118 ELa118cat === Setup ended ===
When I run the NETVerifier tool from my install disk it detects both .NET Framework 4 Client and .NET Framework 4 Full without any issues.
Anyone can help me with this?
Attatched both the Installer and NETVerifier logs just in case
