I've tried several times to install the Revit dvd on my laptop and it seems to freeze at "1 out of 3" remaining. Any thoughts on why this might be happening?
Hi Iroth76;
If you can provide the installation log files we can likely narrow down the issue.
dwayne
Hi Dwayne
Thanks for your reply. The error message I get reads the following: "Error 1305. Error reading from file D:/x86/RAC2012/Program Files/Autodesk/Root/Program/fbxrenderermr-2_5.dll. Verify that the file exists and that you can access it."
thanks
HI Irot76
I'm assuming that the d:/ drive is a DVD or USB drive. I would try creating a folder on your desktop and copying the contents of d:/ to that folder to ensure that there's no issue or corruption with the drive. Then try to install from the deskopt package
dwayne
Hi Dwayne
OK--I've tried transferring the files from the cd to my computer but it started again to automatically to install. I received another error message this time. Here are the notes.
1/1:17:21:32 Lauren Venu LAURENVENU-PC === Setup started on LAURENVENU-PC by Lauren Venu ===
2011/11/1:17:21:32 Lauren Venu LAURENVENU-PC Launch
2011/11/1:17:23:11 Lauren Venu LAURENVENU-PC PageOpen LaunchDialog
2011/11/1:17:25:17 Lauren Venu LAURENVENU-PC PageOpen LicenseDialog
2011/11/1:17:25:21 Lauren Venu LAURENVENU-PC PageOpen ProductInfoDialog
2011/11/1:17:25:43 Lauren Venu LAURENVENU-PC PageOpen ProductSelectionDialog2
2011/11/1:17:25:55 Lauren Venu LAURENVENU-PC PageOpen FullProgressDialog
2011/11/1:17:25:55 Lauren Venu LAURENVENU-PC Installing DirectX® Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2011/11/1:17:29:26 Lauren Venu LAURENVENU-PC Install DirectX® Runtime Succeeded
2011/11/1:17:29:31 Lauren Venu LAURENVENU-PC Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="D:\x86\en-us\RAC2012\RAC2012.mst;C:\Users\LAUREN~1\AppData\Local\Temp\_AI63E1.tmp\x86\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/11/2:12:55:29 Lauren Venu LAURENVENU-PC Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
2011/11/2:13:20:48 Lauren Venu LAURENVENU-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Does this provide any further clues?
thanks!
