What is the error message you get when you try to start Maya 2008 with standalone license.
Some Tips.
- You will need to stop the Floating license service first. Use Flexlm License utilities (LMtools) under start/stop/reread to stop server and make sure that these service is not started upon power up. See attach screen shots.
- Make sure that the HOSTID of your standalone license matches to that of your machine.
- Your standalone license file should be lated in c:\flexlm folder.
- Name your standalone file as aw.dat
- Keep only the aw.dat in c:\flexlm. The rest of the files in there, move it to another location.
What I suspect is that the standalone license maybe using wrong MAC ID (host id).
Also can you check if you have set any environment such as LM_LICENSE_FILE, if yes then remove it.
Hope that helps.
Cheers
Anil
Autodesk Product Support
Anil Choudhary
Product Support Specialist
Autodesk, Inc.
