Installation & Licensing
Transfer License 2007 LT using PLU
1 REPLY 1
goetzinger
224 Views, 1 Reply
--how get number of target computer?  Load on target PC and open PLU?
Do I load the 2007 program on the target computer and open PLU?  After loading, will I be able to open the PLU?
1 REPLY 1
TravisNave
in reply to: goetzinger
Welcome to the community.
You can attempt this if you want.  However, the PLU works aboout -1 times out of 10.  Smiley Very Happy
If your license is still valid (meaning it was never upgraded, cross-graded, or under expired Subscription) then you should be able to just install it on the new workstation and activate it over the Internet.  If you need a manual activation you can do so.  It's way better than messing with the PLU.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Good Luck!
Autodesk Forums:
Administrator Productivity
