Installation & Licensing
Transfer Autocad 2004 to a New Server
5 REPLIES 5
406 Views, 5 Replies
We have AutoCAD 2004 server with three licenses on an old NT 4.0 server. Is there a written procedure regarding how to uninstall and reinstall it onto a new server running Windows 2003 Server?
john0109
5 REPLIES 5
TravisNave
You should just be able to install your FlexLM License Manager on your new Win2k3 Server. Get a new AutoCAD license .lic file from Autodesk or your Reseller. Then change the licpath.lic files in your AutoCAD folder to reflect the new server name and ethernet address.
Retire your NT4 Server.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you. I done what you suggested. Now, how do I tell the workstations to obtain a lincense from the new server? I hope I do not have to reinstall AutoCad at each workstation.
john0109
Sorry!!! I did not read your entire reply.
john0109
TravisNave
No problem. I should have put it clearly on a separate line.
You shouldn't have to reinstall at all. Just find that LICPATH.LIC file and replace the information with the new server name and MAC address. Should be the same as your .LIC file on your server and in your FlexLM System Settings tab.
Good luck!
Autodesk Forums:
I have a VBScript running when a user log in and set it like this:
On Error Resume Next
Set WshShell = Wscript.CreateObject("Wscript.Shell")
Set WshSysEnv = WshShell.Environment("SYSTEM")
WshSysEnv.item("ADSKFLEX_LICENSE_FILE") = "@SERVER1;@SERVER2;@SERVER3"
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) -
http://www.jtbworld.com/?/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2005 and 2006
http://www.jtbworld.com/autocad2005.htm
http://www.jtbworld.com/autocad2006.htm
wrote in message news:4846493@discussion.autodesk.com...
john0109
Administrator Productivity
