• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Trail Version AutoCAD 2013 Will Not Initiate
    1424 Views, 10 Replies
    04-19-2012 11:41 AM
    I have installed - removed - reinstalled AutoCAD 2013 several times. It loads completely. Once I try to launch AutoCAD 2013 it loads up but freezes every time when it gets to Checking License. This is a trial version for 30 days before I buy. I have turned off firewalls and did everything I could thing of. It simply will not get past locking during initialization once it hits checking for license. I don't have a license yet since it is a trial version download directly from AutodesAuto desk .
    What is going wrong? I am using Win7 Home Premium. It has plenty of speed and space.
    Please use plain text.
    Re: Trail Version AutoCAD 2013 Will Not Initiate
    05-31-2012 07:44 AM in reply to: bitemeborb
    Well this was totally useless. I can't use Auto cad 2013 because I cannot find out who has an answer to this simple question.
    TravisNave
    05-31-2012 09:10 AM in reply to: bitemeborb
    Check your registry to make sure your region is set correctly.  There is very similar information in a link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-Simulation-CFD-Licence-problems/m-p/34...
    Just check your AutoCAD 2013 registry for the same.
    For additional information, please consider using Search to assist in your resolution:
    Search Autodesk.com
    Search Autodesk Discussion Groups
    Search Up and Ready Blog
    Search Autodesk WikiHelp
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    06-01-2012 07:46 PM in reply to: TravisNave
    I verified my registry and it is set for en-us. I still has the same exact problem. When you first start AutoCad 2013 and it starts to initialize and locks up and in the the bottom left corner it locks at "Checking license..."
    There is nothing on any blog or any help what so ever from AutoDesk support if can even contact them. Just keep getting refrred to Knowledge Base or Blogs for answers. AutoCad is a tremendous program. It just does not work and has little to no human support for their product.
    06-01-2012 08:21 PM in reply to: TravisNave
    I checked the Registry and it is set correctly at "en-us". My graphics driver is up to date. Why won't this get past the splash screen?
    06-04-2012 07:21 AM in reply to: bitemeborb
    My conclusion: AutoCAD 2013 does not work on my W7 64-bit machine. The Autodesk Knowledge base does not address this issue. The Autodesk blog section failed to address the issue. Autodesk support falied to fix the problem by referring me back to the Knowledge base.
    I have run out of ideas how to fix it and frustrated with the lack of support concern from Autodesk.
    My Recommendation: I wish there was a more viable solution to using Auto desk AutoCAD 2013.
    philip.s
    06-04-2012 01:17 PM in reply to: bitemeborb
    Hi bitemeborb,
    I apologize for the inconvenience and definitely don't want you to think that we don't care or that our support is nonexistent.
    Can you try the suggestions mentioned here and let us know if they resolve the issue?
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    06-04-2012 08:56 PM in reply to: philip.s
    Yes i tried these solutions that i could. Even tried a new user account but that did the same thing. The "Checking license"  would freeze each and everytime at the splash screen.
    Are there any other possible solutions to this bug?
    06-25-2012 10:17 PM in reply to: bitemeborb
    No solution in sight for AutoCAD 2013 locking up during initial splash screen at "checking license". Tried mutiple suggested fixes and all with the exact same outcome. License check during the initial splash screen freezes 100% of the time. Stick with older version of AutoCAD, it worked with far less frustration.
    philip.s
    06-26-2012 02:01 PM in reply to: bitemeborb
    bitemeborb,
    Did you reinstall Windows 7 as my Product Support colleague had suggested? As he believes the blame is the OS and other 3rd party software. Or look at the following potential solutions?
    http://autode.sk/OoomPG
    http://autode.sk/Oootut
    http://autode.sk/OooBu0
    http://autode.sk/OooJdd
    Philip Schmelzer
    TW | PI | YT | BLOG
