Installation & Licensing
Member
Alison24
Message 1 of 5 (11,029 Views)
The software license check out failed. Error 25.
11029 Views, 4 Replies
11-20-2011 01:03 AM
I have Windows XP Professional, and I accidentally uninstalled 3ds Max 2011 (32-bit). I used System Restore to get it back on my laptop, and used the repair option of 3ds Max on the Add or Remove Programs section to try and fix it up. But now whenever I tried opening 3ds max, but it keeps saying 'The software license check out failed. Error 25.'
Can someone help me out?
Product Support
david.lau
Message 2 of 5 (11,008 Views)
Re: The software license check out failed. Error 25.
11-22-2011 10:21 AM in reply to: Alison24
Can you remove the .data file and then re-launch product?  The .data file is located here:
Windows 7
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data_backup.001
Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data_backup.001
David Lau
Member
Alison24
Message 3 of 5 (10,989 Views)
11-22-2011 07:17 PM in reply to: david.lau
I solved it. I deleted the the ProductInformation.pit file that caused the problem and I uninstalled 3ds max to re-installed it, and it worked.
Thanks for the tip. :3
Active Member
aldosa
Message 4 of 5 (10,084 Views)
06-26-2012 01:52 PM in reply to: Alison24
Actually I did get a response from support to this article:
http://forums.autodesk.com/t5/Installation-Licensing/The-software-license-check-out-failed-Error-25/...
which was equally unhelpful since none of the reference files are in my system.
New Member
seebi_92
Message 5 of 5 (7,535 Views)
02-08-2013 12:11 AM in reply to: Alison24
Hello. I have Windows 7 Home Premium and I cannot open Autodesk 3ds Max 2013 x64. I have deleted the file that is in this post but it is not working. I have even uninstalled the program twice and installed back again.
I will upload a picture with the problem.
Any help would be useful.
Thanks.
Sebastian
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
