Installation & Licensing
The program Autodesk Maya2014 Student Version. It is not closed
1 REPLY 1
362 Views, 1 Reply
майя.jpgHello! I had a problem with the program Autodesk Maya2014 Student Version. It is not closed. Please help.
1 REPLY 1
TravisNave
Welcome to the community.
This problem could be caused by a couple of things.
1.  You are running out of heap space in Windows.  You can correct this by using the Fix it option in this Microsoft KB article:
http://support.microsoft.com/kb/947246
2.  You are running into a video driver anamoly.  What you might try doing is upgrading your video card driver to a WHQL certified driver as a clean install and reboot.  Programs like Maya are graphic intensive, so you need to have a stable video driver.  Never run a Microsoft compatible or factory installed driver.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
