I already had the 2014 AutoCAD version on my computer, but it was in portuguese... So i decided to install it in english and now I just can't finish the installation process. It says that have some problem with the System Requirements. To install it in english, i needed to uninstall the portuguese version and install again, because i wasnt getting right on the other way. What do I do?
Solved by m_latz. Go to Solution.
Solved by joane.bonghanoy. Go to Solution.
Hi louisecmarins,
Please check that you met the System Requirements. If so, you can proceed with the uninstallation of the Portuguese version. Click here for the complete uninstallation steps.
Hhm, why uninstall the portuguese version. I recommend to install the english language pack, so you can use both.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=21282814&linkID=9240618
regards
Markus
Hi louisecmarins,
Both Joane's and m.latz's posts are good information to your issue. I've marked them as solutions.
