Is it possible to switch the licensing from network licensing to stand-alone-licensing using a HULA without re-installing Maya?
greetings
kw
Hi Karl and welcome to the forums
The HULA license are provided in Standalone deployment. Do you need to reactivate it or do you want to install it in Network?
Thanks!
hello,
i already have a network license running, which forces me to stay connected to the license server via VPN. Using a local license (in this case a HULA i already have) would safe me from occasional connection fails.
so my question is, whether i can change the network license installation to use the HULA (of course as stand-alone)instead, withut having to re-install MAYA.
cheers
kw
Thanks for these additional information.
I guess it won't be a problem to re-activate your Maya with the HULA licence.
When you open the software, click on the "?" and on "about the licence". You should see a pop-up window with an "activate" button.
Click on it and enter serial number and product key of the HULA licence.
Let me know if it doesn't work.
cheers
kw
no you can not to switch between the 2 license types this requires an uninstall/reinstall
DarrenP
