I'm doing network deployment for civil 3d 2010 and I'm trying to figure out how to keep the install from rebooting after it is finished. I'm using zenworks configuration manager for the deployment so I just wrote a simple batch script that executes the same command as the shortcut created by the deployment wizard. I've tried added /norestart to the command, I tried adding REBOOT=ReallySupress, I even tried adding these to the ini file but none of those work. I've tried using the MSIs themselves instead of the deployment and they don't reboot, but the install doesn't work with the MSIs. No matter how I install it that way it comes up with a dll error. I read in another post that this is because the msi install fails to copy all of the files required for installion when run alone. Anyhow, has anyone figure out how to do this? I'd really appreciate the help.
