Installation & Licensing
Support Preferences Millimetres and ISO - AutoCAD 2013
1 REPLY 1
moosabismillah
458 Views, 1 Reply
Hi All,
I have just received Autodesk Building Design Suite Ultimate 2013.
For installations (as we have quite a few number of PC's to install the software on), I create deployments.
For the Autodesk Building Design Suite 2012 when creating a deployment for Inventor 2012, there was a "Support Preferences", under which you could select three options:-
Part Modification - Enable part modifications from within drawings or Disable part modifications from within drawings
Measurement Units Default - Inches or Millimeters
Drawing Standard Default - ANSI, BIS, DIN, GB, GOST, ISO JIS
These setting seems to have disappeared in the 2013 version.
Any ideas where I can set the above in the deployment.
Thanking you in advance.
Moe.
1 REPLY 1
Hi Moe,
Please refer to the link for the new configuration method:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-Installa0/0001-Before_y1/0114-Network_114/0...
Note:
Part Modification - The Part Modification settings have been moved to The Application Options dialog box: Select the Drawing tab, and then select or deselect the Enable part modification from within drawings checkbox to enable or disable
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Antonio Barroca
Product Support Specialist
Autodesk, Inc.
Administrator Productivity
