Hi All,
I have just received Autodesk Building Design Suite Ultimate 2013.
For installations (as we have quite a few number of PC's to install the software on), I create deployments.
For the Autodesk Building Design Suite 2012 when creating a deployment for Inventor 2012, there was a "Support Preferences", under which you could select three options:-
Part Modification - Enable part modifications from within drawings or Disable part modifications from within drawings
Measurement Units Default - Inches or Millimeters
Drawing Standard Default - ANSI, BIS, DIN, GB, GOST, ISO JIS
These setting seems to have disappeared in the 2013 version.
Any ideas where I can set the above in the deployment.
Thanking you in advance.
Moe.
Hi Moe,
Please refer to the link for the new configuration method:
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0000-Installa0/0001-Before_y1/0114-Network_114/0...
Note:
Part Modification - The Part Modification settings have been moved to The Application Options dialog box: Select the Drawing tab, and then select or deselect the Enable part modification from within drawings checkbox to enable or disable
