Experiencing multiple crashes in Inventor Professional 2010. The CER e-mail that is automatically generated following a crash indicates that 2010 Advantage Pack SP2 x64 is available for download. After installing the new update, Inventor fails to open stating that the .exe file could not be found. Only fix available is to uninstall the SP2 update, but then Inventor resumes crashing while working w/ FEA projects and/or STP file imports. Any suggestions? Not having much luck posting a request to the Subscription site and my reseller has offered no assistance to date.
There are two versions of SP2 - One with subscription bonus pack and other without. Please make sure you have installed the correct one from the site below. Did you try installing SP3 after SP2. This might help to fix your crash.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14275047&linkID=9242019
You could try this Addin repair utility,
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018
Hope it helps.
The first link provided points to a file labeled Inventor2010_sub_advantagepack_sp2_x64.msp
Out of curiousity, how is this file different from the link provided by the CER e-mail, Inventor2010_sr20.msp?
Is there a direct link for the Sub_advantage_sp3 file?
You are prefectly right. It should take you to the right build. Sometimes, if your service pack install didn't go through properly, it would evaluate the current one shown our system registry. Thats why I gave the place where you can download the correct service packs manually.Since you mentioned you have crashes after installing SP, can you provide me the email address that you used to submit the crash to Autodesk. This would help me to have an insight on the issue and provide you with some suggestions.
