Installation & Licensing
Student Inventor Pro 2014 corrupt download.
35 REPLIES 35
Message 1 of 36
1611 Views, 35 Replies
I have attempted to download Inventor 2014 multiple times using all three methods: automated download, install now, and browser download (I've used chrome, IE, and Firefox, along with Internet Download Manager, and none of these are working, all area ble to download but none can complete the self extraction process. I have no firewal enabled nor an AV active.I've gotten as far as the install twice and it failed to install the program, both times flashing a "failed" to decompress message. But more often the downloaded file is corrupt or your automated downloader freezes with an error: 0x250000ff. If I download using the browser method the self extraction utillity freezes at various levels of decompression ranging from a few hundred meg to 7.9Gig.
Any help would be appreciated,
Mike
35 REPLIES 35
Message 2 of 36
My apologies...
My system meets all specs. Windows 7 64bit, 16Gig of ram, SSD with adequate space, dual video cards. Etc. I don't believe it to be a hardware issue. And as far as I can tell my software is compatable...
Again, thank you for any help,
Mike
Message 3 of 36
Tried again this morning 3 times all different methods. I've now downloaded and/or attempted to install this program over 10 times. All with no success. I have turned off my routers firewall and placed my mcahine on a DMZ, so I don't beleieve that is the issue. I believe I will be giving up on Autodesks Student program and looking into learning another cad software.
Have a nice day,
Michael
Message 4 of 36
philip.s
My apologies for the inconvenience Michael.
As I'm not sure what the culprit could be here, I've just sent you a Private Message with instructions for a possible workaround / please reply when you have a chance.
Message 5 of 36
in reply to: philip.s
Thank you for your help Phillip. I apologize for my tone earlier. I was getting pretty frutrated with the situation.
I appreciate you time,
Michael
Message 6 of 36
philip.s
You're welcome Michael and no need to apologize / completely understandable 🙂
Message 7 of 36
Philip,
I have exactly the same issue with the Student Inventor 2014 corrupt download. Could you also send me the instructions on how to correct that issue also.
Thank you,
Message 8 of 36
philip.s
Hello Owenn,
Can you please try using a different browser, and/or disabling your firewall and antivirus software to see if that has an impact?
You can download the software directly from utilizing the Browser Download option via Matt, our Virtual Agent.
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Message 9 of 36
michaelfdonovan
I too had a similar issue and was finally able to download and install the various programs (autodesk 360, vault, design review, autodesk, however when I launch the Inventor student program it comes up shows my info at the top, but as soon as I attempt to do anything it provides a running clock "Not Responding"
Thoughts, should I just download 2013 and shelve 2014 for now?  This is my son's first attempt at this and I don't want him to be discouraged
Message 10 of 36
philip.s
in reply to: michaelfdonovan
Hi Michael!
Are you able to verify that your Machine meets or exceeds the Inventor system requirements?
I would say that trying with the 2013 version is not a bad idea, however am thinking that there might be something larger at play which would also impact your ability to use that version.
Message 11 of 36
What was the solution to the original problem? I'm having the same issues. Thanks.
Message 12 of 36
I'm having trouble with the student version too. I managed to install it, but when I run it, I get the following error:
Inventor.exe - Application Error
The application was to start correctly (0x0000142). Click OK to close the application.
<EventData>
  <Data>Inventor.exe</Data>
  <Data>18.0.17000.0</Data>
  <Data>512fe9d7</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.3.9600.16408</Data>
  <Data>523d557d</Data>
  <Data>e06d7363</Data>
  <Data>000000000000ab78</Data>
  <Data>26a4</Data>
  <Data>01cf2763403c7bf3</Data>
  <Data>C:\Program Files\Autodesk\Inventor 2014\Bin\Inventor.exe</Data>
  <Data>C:\WINDOWS\system32\KERNELBASE.dll</Data>
  <Data>7e4f53b4-9356-11e3-bed6-0c84dc26cc32</Data>
  <Data />
  <Data />
  </EventData>
Message 13 of 36
jessica.t
Hi Muhammad,
Looks like this could have to do with a .NET Framework issue. Take a look at this thread for additional troubleshooting steps.
If the problem persists, please respond to this post. Thank you!
Jessica Thrasher
Message 14 of 36
mattwatson07
I am having the exact same issue when I try to install the student version of autodesk inventor 2014.
The self extracting is stalling at 8.09 GB every time I run it. I have re-downloaded both files multiple times.
I have checked my system settings and they seem to be more than adequate.
Please would you send me the link to re-download an uncorrupt version.
Message 15 of 36
edgarremedios
Gives me this error "File Corrupted error" Anyone know how to help me
Message 16 of 36
jessica.t
in reply to: mattwatson07
Hi Matt,
Try re-downloading your software from our Virtual Agent. Please let me know if this helps!
Jessica Thrasher
Message 17 of 36
jessica.t
in reply to: edgarremedios
Hi Edgar and welcome to the Autodesk Community!
Please try the following to help resolve the error:
- Clear the cookies and cache from your preferred browser
- Temporarily disarm firewalls or antivirus software
- Turn off UAC
- Then try downloading from our Virtual Agent
If you have further questions please let me know. Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. Thank you!
Jessica Thrasher
Message 18 of 36
NathanielMulder
in reply to: jessica.t
Hello I have a similar problem, I;ve been able to download and install the Student Inventor Pro 2014 but I can't seem to get it to install properly. I've tried on two different machines (one running Windows 7 and the other running Windows 8.1, which meet the system requirements) both of which are giving me the error 0xc0000142 "the application was unable to start correctly" i have tried a repair and a reinstall and nothing seem to work. Please advise.
-NM
Message 19 of 36
jessica.t
in reply to: NathanielMulder
Hi NathanielMulder and welcome to the Autodesk Community!
Did you try all of the steps listed in my post above? Was there any change at all? Also, you'll probably have the best luck installing on the Windows 7 machine. Windows 8 is supported but we still have some issues with Windows 8.1.
Jessica Thrasher
Message 20 of 36
I am having the exact same problem. i have tryed to download it on my laptop and it worked but the scereen was too small so i tryed to get it on my pc but no matter what browser i use or download option it still fails at the extracting proccess. My firewll is disabled and AV off. can you please help as it is for doing school work on. (inventor pro 2013 as it is compatable with my scool pc's)
Tags (1)
Administrator Productivity
