Installation & Licensing
Stuck on AutoCAD2014 installation
1 REPLY 1
403 Views, 1 Reply
When I'm trying to install AutoCAD 2014, it gets stuck in one point: the progressing bar doesn't move, it doesn't give any error messages.
- I'm logged on a local user account with administrator access
-  After checking the log on %TEMP% the last thing that does is creating the shortcuts under start menu->programs, but when trying to run it, it won't open (acad.exe doesn't exist at all at that location)
I will appreciate your help.
1 REPLY 1
TravisNave
Wait it out.  I have seen some installations take over 8 hours.  Run it overnight and see if it is there in the morning.
It also helps to make sure the anti-virus and UAC are both off.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
