Installation & Licensing
Member
AngusGibbins
Message 1 of 3 (973 Views)
Stop Automatic Reboot of Silent AutoCAD 2011 installation
973 Views, 2 Replies
03-28-2011 09:06 PM
Is there a way of stopping the automatic reboot that happens at the end of an AutoCAD 2011 silent installation at all?
I've gone through and installed the prerequisits but the installer still does a reboot afterwards.
Employee
alison.gangler
Message 2 of 3 (911 Views)
Re: Stop Automatic Reboot of Silent AutoCAD 2011 installation
03-30-2011 08:53 AM in reply to: AngusGibbins
The reboot at the end of the install is a function controlled by Windows Installer. There are some suggestions to help avoid this at the following discussion:
http://forums.autodesk.com/t5/Installation-Licensing/Network-install-of-AutoCAD-2011-causes-reboot/t...
In addition, there is more information regarding suppression of reboots on MSDN:
http://msdn.microsoft.com/en-us/library/aa371101(v=vs.85).aspx
Generally, installing the prerequisites for the product before the main install will resolve the problem.
If you are launching the install from another application such as SCCM, then applying the property, REBOOT=ReallySuppress to the command line will sometimes help. You can modify the setup.ini, adding the REBOOT=ReallySuppress  to the EXE_PARAM= section of the INI file for the prerequisites which trigger the reboot. In order to determine which prerequisite package causes the reboot, you can enable verify the contents of the Setup.log which should list the package triggering the reboot.
Please be aware that the reboot is scheduled by Windows Installer to maintain the integrity of the components in the OS so it is highly recommended to reboot prior to launching the software to ensure that there will be no compromise of the component integrity.
Please let me know if this helps or if you have further questions.
Alison Gangler, Autodesk Product Support
Alison Gangler
Thanks.
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
Member
vidyarth
Message 3 of 3 (494 Views)
01-22-2012 11:18 PM in reply to: AngusGibbins
I m currently trying to deploy the Autocad Mechanical 32 bit for Windows xp through a 3 party deployment tool.
I m also facing this reboot issue which we have to suppress.Kindly provide us with a resolution so that we can proceed further with this application.i Have tried manually installing the pre requistes and we have windows installer version 4.5 installed on the system.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
