Installation & Licensing
Start up propblems autocad14
3 REPLIES 3
Badar-Ahmad
392 Views, 3 Replies
Hi
i have a propblem i want to start my autocad 14 but it says HDI file is missing so i dont know how to fi this propblen
3 REPLIES 3
TravisNave
in reply to: Badar-Ahmad
This is typical of either an incompatible video card driver or a problem with AutoCADs video driver.  You can either update your video driver (nVidia or ATI, etc.) or you can try reinstalling AutoCAD.  Both usually resolve the problem.
Alternately, you may be able to resolve this problem in one of the following ways:
At the command line, enter 3dconfig. Click the Manual Tune button. Toggle the checkbox for Enable hardware acceleration. Click OK twice.
If that doesn't work, right-click the program icon on your desktop. Click Properties. Click the Shortcut tab. In the Target field, after *.exe”, type a space and enter /NOHARDWARE
You should now be able to launch AutoCAD.
Good Luck!
Autodesk Forums:
Badar-Ahmad
thx it worked
rafa14091996
Ajudou Bastante. OBRIGADO!
Administrator Productivity
