Installation & Licensing
New Member
baumannk1
Message 1 of 2 (3,484 Views)
Some products failed to install
3484 Views, 1 Replies
06-07-2012 08:34 AM
Tried to install Autocad on windows 7 pro, but keeps getting denied mid install.
Keep getting the error message "Installation Complete, some products failed to install"
is there anyone who can help troubleshoot this problem for me?
thank you for your help
2012/6/6:21:16:47 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/6:21:16:47 Baumann BAUMANN-THINK Launch 2012/6/6:21:16:56 Baumann BAUMANN-THINK === Setup ended ===
2012/6/6:21:16:51 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/6:21:16:51 Baumann BAUMANN-THINK Launch 2012/6/6:21:16:56 Baumann BAUMANN-THINK PageOpen LaunchDialog   2012/6/6:21:17:01 Baumann BAUMANN-THINK You are attempting to use a 32-bit installer on a 64-bit operating system.
Please exit and use the 64-bit installer available from your installation media or from Autodesk.com.2012/6/6:21:17:14 Baumann BAUMANN-THINK === Setup ended ===
2012/6/7:01:13:17 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/7:01:13:17 Baumann BAUMANN-THINK Launch 2012/6/7:01:13:24 Baumann BAUMANN-THINK === Setup ended ===
2012/6/7:01:13:20 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/7:01:13:20 Baumann BAUMANN-THINK Launch 2012/6/7:01:13:24 Baumann BAUMANN-THINK PageOpen LaunchDialog   2012/6/7:01:13:28 Baumann BAUMANN-THINK PageOpen LicenseDialog   2012/6/7:01:13:32 Baumann BAUMANN-THINK PageOpen ProductInfoDialog   2012/6/7:01:14:07 Baumann BAUMANN-THINK PageOpen ProductSelectionDialog2   2012/6/7:01:14:11 Baumann BAUMANN-THINK PageOpen FullProgressDialog   2012/6/7:01:14:11 Baumann BAUMANN-THINK Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart 2012/6/7:01:17:54 Baumann BAUMANN-THINK Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603 2012/6/7:01:17:56 Baumann BAUMANN-THINK PageOpen InstallCompleteDialog   2012/6/7:01:19:08 Baumann BAUMANN-THINK === Setup ended ===
2012/6/7:09:14:22 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/7:09:14:22 Baumann BAUMANN-THINK Launch 2012/6/7:09:14:32 Baumann BAUMANN-THINK === Setup ended ===
2012/6/7:09:14:25 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/7:09:14:25 Baumann BAUMANN-THINK Launch 2012/6/7:09:14:31 Baumann BAUMANN-THINK PageOpen LaunchDialog   2012/6/7:09:15:04 Baumann BAUMANN-THINK PageOpen LicenseDialog   2012/6/7:09:16:52 Baumann BAUMANN-THINK PageOpen ProductInfoDialog   2012/6/7:09:17:30 Baumann BAUMANN-THINK PageOpen ProductSelectionDialog2   2012/6/7:09:17:37 Baumann BAUMANN-THINK PageOpen FullProgressDialog   2012/6/7:09:17:37 Baumann BAUMANN-THINK Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart 2012/6/7:09:24:44 Baumann BAUMANN-THINK Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603 2012/6/7:09:24:46 Baumann BAUMANN-THINK PageOpen InstallCompleteDialog   2012/6/7:09:31:58 Baumann BAUMANN-THINK === Setup ended ===
2012/6/7:10:43:25 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/7:10:43:25 Baumann BAUMANN-THINK Launch 2012/6/7:10:43:35 Baumann BAUMANN-THINK === Setup ended ===
2012/6/7:10:43:30 Baumann BAUMANN-THINK === Setup started on BAUMANN-THINK by Baumann === 2012/6/7:10:43:30 Baumann BAUMANN-THINK Launch 2012/6/7:10:43:35 Baumann BAUMANN-THINK PageOpen LaunchDialog   2012/6/7:10:43:41 Baumann BAUMANN-THINK PageOpen LicenseDialog   2012/6/7:10:43:48 Baumann BAUMANN-THINK PageOpen ProductInfoDialog   2012/6/7:10:44:00 Baumann BAUMANN-THINK PageOpen ProductSelectionDialog2   2012/6/7:10:44:05 Baumann BAUMANN-THINK PageOpen FullProgressDialog   2012/6/7:10:44:05 Baumann BAUMANN-THINK Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart 2012/6/7:10:48:07 Baumann BAUMANN-THINK Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
TravisNave
Message 2 of 2 (3,480 Views)
Re: Some products failed to install
06-07-2012 09:39 AM in reply to: baumannk1
Install .N​ET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
