Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
Some Products Fail to Install, Result 1603
280 REPLIES 280
Message 1 of 281
TravisNave
807414 Views, 280 Replies
Issue:  When installing your Autodesk product, the installation fails immediately and the screen indicates that Installation complete. Some products failed to install
The link to the installation log file in your %TEMP% location shows that the failure is due to a prerequisite installer similar to this entry below:
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Subseqent attempts to install the product yield similar failures.
Solution #1:  In some rare instances, the prerequisite cannot installed until the workstation is rebooted, or cannot be installed by the Autodesk installer and must be installed manually from the media or by downloading the prerequisite directly from Microsoft's website.  For more information about this solution, please visit this Autodesk KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15924324&linkID=9240857
Solution #2:  In most instances, the installation fails because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer.  Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
The most direct method to resolve this issue is to remove the installed prerequisite from Windows from within the Control Panel.  You can launch the Control Panel directly from the Start Menu or from the Run box by typing CONTROL and clicking OK.
To remove a program in Control Panel choose:
Windows XP: Add/Remove Programs
Windows 7:  Programs and Features
Locate the program name of the prerequisite that is failing in your log file from within this list and click Remove or Uninstall.  This will remove the program from your computer.
Once the program has been removed, run your Autodesk installer again.  If you run into additional failures on prerequisites, repeat the process.  You should now be able to fully install and run your product.
For more information about this error, please see the Up and Ready blog link here:
http://upandready.typepad.com/up_and_ready/2011/09/autodesk-suites-product-design-suite-will-not-ins...
Note:  When installing Autodesk products, it is recommended that you have local Administrative rights, User Access Control (UAC) is off, and your real-time anti-virus program is temporarily disabled. In some instances it may be helpful to login as another user with local admin rights and/or copy the contents of the media to you hard drive and install locally.
Autodesk Forums:
Tags (2)
280 REPLIES 280
Message 61 of 281
TravisNave
in reply to: andri_cobb
It's a failed download. Use the virtual agent to download your product.
That should work.
Autodesk Forums:
Message 62 of 281
ScottC
in reply to: TravisNave
Same problem for us (2 machines so far).
Autodesk Reseller advised us to untistall Microsoft Visual C++ 2005 Redistributabl5 but to no avail...
2014/6/5:16:29:25 alexc PC-1618 === Setup started on PC-1618 by alexc ===
2014/6/5:16:29:25 alexc PC-1618 Path_Length: 149
2014/6/5:16:29:25 alexc PC-1618 Current Directory C:\Autodesk\Autodesk_Revit_LT_2014_English_Win_32-64bit_dlm
2014/6/5:16:29:25 alexc PC-1618 Launch
2014/6/5:16:29:25 alexc PC-1618 CommandLine
2014/6/5:16:29:25 alexc PC-1618 Current Directory C:\Users\alexc\AppData\Local\Temp\_AIC050.tmp
2014/6/5:16:29:37 alexc PC-1618 === Setup ended ===
2014/6/5:16:29:29 alexc PC-1618 === Setup started on PC-1618 by alexc ===
2014/6/5:16:29:29 alexc PC-1618 Path_Length: 149
2014/6/5:16:29:29 alexc PC-1618 Current Directory C:\Users\alexc\AppData\Local\Temp\_AIC050.tmp
2014/6/5:16:29:29 alexc PC-1618 Launch
2014/6/5:16:29:31 alexc PC-1618 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\alexc\AppData\Local\Temp\_AIC050.tmp\Setup\RevitSetup.dll
2014/6/5:16:29:31 alexc PC-1618 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/6/5:16:29:37 alexc PC-1618 PageOpen LaunchDialog
2014/6/5:16:29:40 alexc PC-1618 PageOpen LicenseDialog
2014/6/5:16:29:43 alexc PC-1618 PageOpen ProductInfoDialog
2014/6/5:16:30:10 alexc PC-1618 PageOpen ProductSelectionDialog2
2014/6/5:16:30:21 alexc PC-1618 PageOpen FullProgressDialog
2014/6/5:16:30:21 alexc PC-1618 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_LT_2014_English_Win_32-64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\alexc\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/6/5:16:31:09 alexc PC-1618 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Message 63 of 281
david.lau
in reply to: ScottC
Open setup.ini file and take out "VCREDIST2005X86".
Also Change:
EXE_PATH=3rdParty\x86\VCRedist\2005\vcredist_x86.exe
To:
EXE_PATH=echo
David Lau
Message 64 of 281
telfortsam
in reply to: srlake31470
Hey I need some help on this issue, trying to install MAYA 2013 on my new laptop (wasnt a problem a year ago). I keept getting error messafes. can you email me or call me at telfortsam@yahoo,com
Message 65 of 281
Hi Samnold,
What exactly is the error message? Have you tried doing a Clean Uninstall? After which, you can then download the installation from our Virtual Agent
Joane Bonghanoy
Message 66 of 281
telfortsam
I believe this can work but how do I copy the installation to my C Drive? What are the procedures?
Message 67 of 281
kylie.sharpe94
Thanks, this helped a lot!
Message 68 of 281
rob.kopel
For people who have had 1603 errors on the actual product (e.g. 3ds Max) not DirextX or any other 3rd party product check that your services file is not read only. I recently spend a great deal of time trying to fix an instillation where there was no clear error in the verbose log and I eventually found that my virus protection had permanently set my services file to read only. Also read only overwrites all administrator privileges so it doesnā€™t matter if you install with no UAC on.
Rob
Message 69 of 281
omer
Hi
I've uninstalled all of the Microsoft Visual C++ 2010,2008,2005 Redistributable ,and still nothing is working, same resault every time
attached: instaltion log
Thanks for the help
Omer
Message 70 of 281
TravisNave
in reply to: omer
@omer wrote:
Hi
Thanks for the help
Omer
Your failure is MSVC++ 2005.  Make sure you are installing on a supported OS for Autodesk 2012 (not Windows 8.x)
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
Message 71 of 281
meem.almehairy
I tried to uninstall MSVC++ 2005 but nothing changed, shall I delete 2005, 2008 & 2010?
And by the way I don't know from where can I check the log file??
Thank you very much and I wish I can find a solution ASAP, because I'll start my revit coarse after few days šŸ˜ž
Message 72 of 281
TravisNave
in reply to: meem.almehairy
The log file is in %TEMP%
Find it and post it.  It will help.
Autodesk Forums:
Message 73 of 281
meem.almehairy
I tried to download it many times maybe around four times.. for the first two it shows me the following and the rest two are different, I think it changed because I deleted MSVC++ 2005. Anyway this is the first and second times masseges:
Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\MARYAM~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2014/9/3:06:50:52 maryamalmehairy MARYAMALMEH3BF2 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\MARYAM~1\AppData\Local\Temp\vcredist_x86_2010.log
2014/9/3:06:50:54 maryamalmehairy MARYAMALMEH3BF2 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
And this is the third and fourth times massege:
Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\MARYAM~1\AppData\Local\Temp\vcredist_x86_2010.log2014/9/3:15:49:02                                    maryamalmehairy MARYAMALMEH3BF2 Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Shall I delete MSVC++ 2010?
Message 74 of 281
pilsen120
Hi, I'm a student trying to download Maya 2015, Mental ray 2015 Autodesk direct connect 2015. I'm having the same issue that everyone is having. Starts downloading an then it says "Installation complete some product failed to install" I'm including the logs I got, Thank you for the help. I have home work due on Tuesday o please help me.
Message 75 of 281
JMJ5ZB
I went to my add or remove programs and unistalled all of the redistributable packages that were listed and tried to run the installation again and it still failed giving me the same error message. I then tried dowloading the redistribuatble packages strait from the microsoft website and no matter which version i try to download it says object already exists. I then get a 0x0070643 error message. Yet when i go back to add/remove programs none of them are there so i dont understand why it keeps telling me they already exist. Any sugestions?
Message 76 of 281
jessica.t
in reply to: pilsen120
Hi @pilsen120,
Thank you for your installation log file, the error reads as such:
Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Installation aborted, Result=1619
There could be many causes of this type of error, please see this post on troubleshooting this error created by our Expert Elite and Autodesk product support. If you have any further questions please let us know. Thank you!
Jessica Thrasher
Message 77 of 281
Eldarado
in reply to: rob.kopel
rob.kopel, could you be more specific? Wich file(s) are marked as read only?
Message 78 of 281
TravisNave
@pilsen120  I just recently wrote a HOWTO guide on deciphering the installation log file.
http://forums.autodesk.com/t5/installation-licensing/how-to-determine-errors-in-installation-log-fil...
Thanks.
Autodesk Forums:
Message 79 of 281
jessica.t
Moved:
Your message has been moved to the AutoCAD forums board for better visibility. Thanks!
Message 80 of 281
Mazianne7
I am trying to install Autocad 2013 and I keep getting a communication error & I am unable to get it sorted?
Please help!
Administrator Productivity
