Installation & Licensing
New Member
meizhangdanao
Message 21 of 63 (1,863 Views)
Re: Some Products Fail to Install, Result 1603
09-16-2013 03:16 AM in reply to: TravisNave
2013/9/16:18:00:57 Daqiao LENOVO-G580 === Setup started on LENOVO-G580 by Daqiao === 2013/9/16:18:00:57 Daqiao LENOVO-G580 Path_Length: 155 2013/9/16:18:00:57 Daqiao LENOVO-G580 Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us 2013/9/16:18:00:57 Daqiao LENOVO-G580 Launch 2013/9/16:18:00:57 Daqiao LENOVO-G580 CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/AutoCAD_2014_English_Win_32_64bit_wi_..." /SN 900-34707489 /PK 001F1 /student /skipEULA /akamai /auth  /sid   2013/9/16:18:00:57 Daqiao LENOVO-G580 Path_Length: 155 2013/9/16:18:00:57 Daqiao LENOVO-G580 Current Directory C:\Users\Daqiao\AppData\Local\Temp\_AI631.tmp 2013/9/16:18:04:47 Daqiao LENOVO-G580 === Setup ended ===
2013/9/16:18:01:00 Daqiao LENOVO-G580 === Setup started on LENOVO-G580 by Daqiao === 2013/9/16:18:01:00 Daqiao LENOVO-G580 Path_Length: 155 2013/9/16:18:01:00 Daqiao LENOVO-G580 Current Directory C:\Users\Daqiao\AppData\Local\Temp\_AI631.tmp 2013/9/16:18:01:00 Daqiao LENOVO-G580 Launch 2013/9/16:18:01:02 Daqiao LENOVO-G580 Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7... 2013/9/16:18:04:46 Daqiao LENOVO-G580 Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7... 2013/9/16:18:04:46 Daqiao LENOVO-G580 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Daqiao\AppData\Local\Temp\_AI631.tmp\Setup\AcSetup.dll 2013/9/16:18:04:46 Daqiao LENOVO-G580 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink= 2013/9/16:18:04:46 Daqiao LENOVO-G580 PageOpen LaunchDialog   2013/9/16:18:05:08 Daqiao LENOVO-G580 PageOpen LicenseDialog   2013/9/16:18:05:08 Daqiao LENOVO-G580 PageOpen ProductInfoDialog   2013/9/16:18:05:08 Daqiao LENOVO-G580 PageOpen ProductSelectionDialog2   2013/9/16:18:08:00 Daqiao LENOVO-G580 PageOpen FullProgressDialog   2013/9/16:18:08:02 Daqiao LENOVO-G580 Download Play DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7... 2013/9/16:18:13:02 Daqiao LENOVO-G580 Download Complete DOTNET4LANG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/EDU/{F5F376DB-F616-49B6-B7C4-89AEF0DF4FB7... 2013/9/16:18:13:02 Daqiao LENOVO-G580 Installing .NET Framework Runtime 4.0 Language Pack: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe" /q 2013/9/16:18:13:08 Daqiao LENOVO-G580 Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
I tried the ways you mentioned but it doesn't work, still shows "some products fail to install".
Any soultions?
TravisNave
Message 22 of 63 (1,854 Views)
09-16-2013 09:18 AM in reply to: meizhangdanao
Your problem is something similar that I have addressed in another thread.
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
kayron.7
Message 23 of 63 (1,595 Views)
11-17-2013 06:11 PM in reply to: TravisNave
Thanks. My problem was solved.
TravisNave
Message 24 of 63 (1,594 Views)
11-17-2013 06:14 PM in reply to: kayron.7
Excellent. Always glad when my solutions help.
Member
OkiGraphics
Message 25 of 63 (1,556 Views)
11-20-2013 02:34 PM in reply to: TravisNave
Hello!
Im havig trouble  install Inventor 2014 (older versions also). At first, I had 1603 error right after install started. I have solved this problem by editing Setup.ini file. But now, right before end of install Inventor, I get another error:
Error 1935. An error occurred during the installation of assembly 'Microsoft.MSXML2,publicKeyToken="6bd6b9abf345378f",version="4.20.9818.0",type="win3 2",processor Architecture="x86". Please refer to help and support for more information
 Log from installation as an addition.
I have tried this: http://support.microsoft.com/kb/902330 but it was't solution for me.
Also, I have:
  • disabled windows defender
  • ran installaton as an adminitrator
  • checked I have 64 bit system and I'm installing 64 bit Inventor
  • cleared TEMP
  • updated DirectX
  • and everything else I have found in possible solutions, but I can't remember now...
Im using HP Envy 15-j000ec and Windows 8
I will really grateful if someone will be able to help me with this problem, because I really need Inventor to do my term project.
TravisNave
Message 26 of 63 (1,544 Views)
11-20-2013 02:45 PM in reply to: OkiGraphics
It's likely .NET Framework.  You might try reinstalling what you have.  Also, check your programs & features under Control Panel and make sure that you add the older .NET as part of adding Windows components.  They are not installed by default on Win8.  So you might start there and try again.
Member
OkiGraphics
Message 27 of 63 (1,500 Views)
11-22-2013 12:55 PM in reply to: TravisNave
Thanks for your reply. Actually, I can't see .NET  in programs & features list, but when I'm trying to install it, I says I have the same or newer version installed, so I don't think that is the problem.
New Member
vlandrov
Message 28 of 63 (1,488 Views)
11-22-2013 02:29 PM in reply to: TravisNave
IT worked!!! It really worked!!! THANKYOU!!!
My problem was .net framework 4.0 error 1603. I erased every dotnet line in the file u said.
Member
OkiGraphics
Message 29 of 63 (1,415 Views)
12-03-2013 10:57 AM in reply to: OkiGraphics
Don't you really have other solutions for me? I'm really hopeless about it. I really need to work on my term project this weekend, and I can't even install it...
TravisNave
Message 30 of 63 (1,410 Views)
12-03-2013 02:31 PM in reply to: OkiGraphics
Check the Windows components section of Programs and Features.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
