Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Some Products Fail to Install, Result 1603
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Issue: When installing your Autodesk product, the installation fails immediately and the screen indicates that Installation complete. Some products failed to install.
The link to the installation log file in your %TEMP% location shows that the failure is due to a prerequisite installer similar to this entry below:
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Subseqent attempts to install the product yield similar failures.
Solution #1: In some rare instances, the prerequisite cannot installed until the workstation is rebooted, or cannot be installed by the Autodesk installer and must be installed manually from the media or by downloading the prerequisite directly from Microsoft's website. For more information about this solution, please visit this Autodesk KB link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Solution #2: In most instances, the installation fails because the prerequisite already installed on the workstation is newer than the one supplied by the Autodesk installer. Because Windows will not allow an older version of the prerequisite to be installed, the installation aborts with a 1603 error in the installation log file.
The most direct method to resolve this issue is to remove the installed prerequisite from Windows from within the Control Panel. You can launch the Control Panel directly from the Start Menu or from the Run box by typing CONTROL and clicking OK.
To remove a program in Control Panel choose:
Windows XP: Add/Remove Programs
Windows 7: Programs and Features
Locate the program name of the prerequisite that is failing in your log file from within this list and click Remove or Uninstall. This will remove the program from your computer.
Once the program has been removed, run your Autodesk installer again. If you run into additional failures on prerequisites, repeat the process. You should now be able to fully install and run your product.
For more information about this error, please see the Up and Ready blog link here:
Note: When installing Autodesk products, it is recommended that you have local Administrative rights, User Access Control (UAC) is off, and your real-time anti-virus program is temporarily disabled. In some instances it may be helpful to login as another user with local admin rights and/or copy the contents of the media to you hard drive and install locally.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Solved! Go to Solution.
Re: Some Products Fail to Install, Result 1603
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Advanced Solution: In some instances, it is possible to install the product with the existing newer prerequisites already installed. To do this requires more advanced installation knowledge.
Step 1: Copy the entire contents of your installation media to a folder on your local hard drive. If you have a downloaded version, this is not necessary as the files are already on your hard drive.
Step 2: Located the Setup.ini file and create a backup of this file.
Step 3: Open the file in a text editor, such as Notepad.
Step 4: Do a search for the prerequisites that are failing. If your installation is failing on Microsoft Visual C++ Redistributable, do a search for VCREDIST. If it is for Microsoft .NET Framework, search for DOTNET. These items should be located in a PREREQUISITE line that looks similar to this entry:
PREREQUISITE=IE;SSE2;VCREDIST2008SP1X86;VCREDIST20
Step 5: Delete all instances listed for the prerequisites in the PREREQUISITE= line for that product which is failing. For example, if you were deleting the prerequisite for .NET Framework, your PREREQUISITE= line above would now look like the following:
Step 6: Delete the section for the #== 3rd Party Components == prerequisite itself between the comment lines. This section will be at the bottom of the Setup.ini file. Again, if you were deleting .NET Framework, you should be left with a blank section similar to this:
#============= DOTNET Begin ===============
#============= DOTNET End ===============
Step 7: Save the Setup.ini file and run the Setup.exe file to begin the Autodesk installation. The installation should now skip the check for the prerequisite files and install without error.
Note: It is important to have the prerequisite programs installed prior to this advanced installation solution. If you do not have the prerequisites properly installed, your Autodesk program will not run!
This process may not work for everyone. Please use caution when modifying your installation files. For an example of an AutoCAD 2012 (vanilla) setup.ini file modified for the removal of .NET Framework, see the attached file. I do not recommend using this file in place of your own.
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Some Products Fail to Install, Result 1603
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thx a lot ![]()
The uninstalling procedure fixed my problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello! I just installed the trial version of Autodesk 3ds Max 2011 x64. I downloaded the files and the supplementry files to my documents per instructions. I unzipped all the files,. but when I click open file on the Quick Access toolbar and try to open the battlefield scene, all I get every time is "File Open Failed". I removed all the files and reloaded them twice, but I get the same results each time. Am I doing something incorrectly?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
TravisNave,
I am also having some issues when installimng Revit MEP 2013...
This is the messga that I am getting:
2012/5/2:21:38:05 Jose Oliveira JOSEOLIVEIRA === Setup started on JOSEOLIVEIRA by Jose Oliveira === 2012/5/2:21:38:05 Jose Oliveira JOSEOLIVEIRA Launch 2012/5/2:21:38:09 Jose Oliveira JOSEOLIVEIRA PageOpen LaunchDialog 2012/5/2:21:38:15 Jose Oliveira JOSEOLIVEIRA PageOpen LicenseDialog 2012/5/2:21:38:17 Jose Oliveira JOSEOLIVEIRA PageOpen LaunchDialog 2012/5/2:21:38:18 Jose Oliveira JOSEOLIVEIRA PageOpen LicenseDialog 2012/5/2:21:38:26 Jose Oliveira JOSEOLIVEIRA PageOpen ProductInfoDialog 2012/5/2:21:39:11 Jose Oliveira JOSEOLIVEIRA PageOpen ProductSelectionDialog2 2012/5/2:21:40:02 Jose Oliveira JOSEOLIVEIRA PageOpen FullProgressDialog 2012/5/2:21:40:02 Jose Oliveira JOSEOLIVEIRA Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): J:\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2012/5/2:21:40:12 Jose Oliveira JOSEOLIVEIRA Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2012/5/2:21:40:12 Jose Oliveira JOSEOLIVEIRA Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): J:\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2012/5/2:21:40:19 Jose Oliveira JOSEOLIVEIRA Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2012/5/2:21:40:19 Jose Oliveira JOSEOLIVEIRA Installing DirectX® Runtime: J:\3rdParty\DirectX\DXSETUP.exe /silent 2012/5/2:21:41:36 Jose Oliveira JOSEOLIVEIRA Install DirectX® Runtime Succeeded 2012/5/2:21:41:36 Jose Oliveira JOSEOLIVEIRA Installing FaroSDK: J:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\JOSEOL~1\AppData\Local\Temp\FaroSDK .log" 2012/5/2:21:41:42 Jose Oliveira JOSEOLIVEIRA Install FaroSDK Succeeded 2012/5/2:21:41:42 Jose Oliveira JOSEOLIVEIRA Installing Autodesk® Revit® MEP 2013: TRANSFORMS="J:\x64\en-us\RME2013\RME2013.mst;C:\Us ers\JOSEOL~1\AppData\Local\Temp\_AID5E4.tmp\x64\RM E2013\RME2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="J:\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2012/5/2:21:42:11 Jose Oliveira JOSEOLIVEIRA Install Autodesk® Revit® MEP 2013 Failed Installation aborted, Result=1603 2012/5/2:21:42:11 Jose Oliveira JOSEOLIVEIRA Rollback FaroSDK Failed Failure is ignored, Result=1619 2012/5/2:21:42:11 Jose Oliveira JOSEOLIVEIRA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/5/2:21:42:11 Jose Oliveira JOSEOLIVEIRA Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2012/5/2:21:42:11 Jose Oliveira JOSEOLIVEIRA Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
I did unistall the 'Microsoft Visual C++ 2010 SP1 Redistributable (x86)' and 'Microsoft Visual C++ 2010 SP1 Redistributable (x64)' but unfortunately didn't work!
Any other ideas or suggestions?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your problem does not fit this solution as your log shows your prerequisite programs are installing correctly. Your problem is a 1603 on the application install itself. Please copy the contents of the installation locally to a folder on your C:\ and install from there under a different user with local admin rights, UAC disabled, and anti-virus turned off.
ATTENTION: FOR BETTER AND FASTER RESULTS, PLEASE CREATE A NEW THREAD IN THE FORUM RATHER THAN MAKING A NEW REPLY TO THIS ONE. THANK YOU.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I understand that you said to create a new thread, but I just have a general question: will this be fixed at all? I have to deploy a few different configurations to a number of labs and individual computers, most of which have some of the prereqs already installed with newer versions, although what prereqs are installed differs between lab and computer. Why doesn't the installer just check to see if a new version is already installed, and skip attempting to install the prereq if it is? I'm not trying to be difficult, but this seems like quite an oversight and it's made generating deployments practically useless for me.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Modify your ini file not to check for the prereqs per my detailed instructions. Rather than respond to this thread, you could have sent me a PM. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello, I've got similar problem when installing softimage.
My first log showed that I had faluire on C++, the other logs after that (as I tried to install several times more) showed sth like this:
2012/10/11:00:15:45 JOKER JOKER-PC === Setup started on JOKER-PC by JOKER === 2012/10/11:00:15:45 JOKER JOKER-PC Launch 2012/10/11:00:15:52 JOKER JOKER-PC === Setup ended ===
2012/10/11:00:15:48 JOKER JOKER-PC === Setup started on JOKER-PC by JOKER === 2012/10/11:00:15:48 JOKER JOKER-PC Launch 2012/10/11:00:15:53 JOKER JOKER-PC PageOpen Launch
2012/10/11:00:22:13 JOKER JOKER-PC Install Autode
2012/10/11:00:34:50 JOKER JOKER-PC === Setup started on JOKER-PC by JOKER === 2012/10/11:00:34:50 JOKER JOKER-PC Launch 2012/10/11:00:34:57 JOKER JOKER-PC === Setup ended ===
2012/10/11:00:34:54 JOKER JOKER-PC === Setup started on JOKER-PC by JOKER === 2012/10/11:00:34:54 JOKER JOKER-PC Launch 2012/10/11:00:34:54 JOKER JOKER-PC [Error: 1052] The requested control is not valid for this service. 2012/10/11:00:34:57 JOKER JOKER-PC PageOpen Launch
2012/10/11:00:40:44 JOKER JOKER-PC Install Autode
As I found this thread quite useful, I tried to install again, but before that I edited the Setup.ini file, I deleted both the VCREDIST and DOTNET under the PREREQUISITE line of SOFTIMAGEX64. But I couldn't find the #== 3rd Party Components ==at the bottom of the Setup.ini file, either in the entire file.
So I left the setup.ini like this to install again, turned out failed again.
I have attached both logs in the message. Seeking for help, thx.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
