2013/9/14:19:31:21 TrevorMcNeill TREVOR === Setup started on TREVOR by TrevorMcNeill === 2013/9/14:19:31:21 TrevorMcNeill TREVOR Path_Length: 151 2013/9/14:19:31:21 TrevorMcNeill TREVOR Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US 2013/9/14:19:31:21 TrevorMcNeill TREVOR Launch 2013/9/14:19:31:21 TrevorMcNeill TREVOR CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_6... /SN 900-41328624 /PK 128F1 /student /skipEULA /akamai /auth /sid 2013/9/14:19:31:21 TrevorMcNeill TREVOR Path_Length: 151 2013/9/14:19:31:21 TrevorMcNeill TREVOR Current Directory C:\Users\TREVOR~1\AppData\Local\Temp\_AI7215.tmp 2013/9/14:19:31:25 TrevorMcNeill TREVOR === Setup ended === 2013/9/14:19:31:22 TrevorMcNeill TREVOR === Setup started on TREVOR by TrevorMcNeill === 2013/9/14:19:31:22 TrevorMcNeill TREVOR Path_Length: 151 2013/9/14:19:31:22 TrevorMcNeill TREVOR Current Directory C:\Users\TREVOR~1\AppData\Local\Temp\_AI7215.tmp 2013/9/14:19:31:22 TrevorMcNeill TREVOR Launch 2013/9/14:19:31:23 TrevorMcNeill TREVOR Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024... 2013/9/14:19:31:25 TrevorMcNeill TREVOR PageOpen LaunchDialog 2013/9/14:19:31:28 TrevorMcNeill TREVOR PageOpen LicenseDialog 2013/9/14:19:31:28 TrevorMcNeill TREVOR PageOpen ProductInfoDialog 2013/9/14:19:31:28 TrevorMcNeill TREVOR PageOpen ProductSelectionDialog2 2013/9/14:19:31:31 TrevorMcNeill TREVOR PageOpen FullProgressDialog 2013/9/14:19:31:32 TrevorMcNeill TREVOR Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024... 2013/9/14:19:31:35 TrevorMcNeill TREVOR Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024... 2013/9/14:19:31:35 TrevorMcNeill TREVOR Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TREVOR~1\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/9/14:19:31:43 TrevorMcNeill TREVOR Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2013/9/14:19:31:43 TrevorMcNeill TREVOR Download Skipped VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024... 2013/9/14:19:31:43 TrevorMcNeill TREVOR Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TREVOR~1\AppData\Local\Temp\vcredist_x64_2005.log"" " 2013/9/14:19:31:50 TrevorMcNeill TREVOR Install Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1603 2013/9/14:19:31:50 TrevorMcNeill TREVOR Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
i have tried so many things suggested on the fourms it has finally installed the 86 version of microsoft c++ but then fails on the 64 version if anyone can help it would be much appreciated
BTW a couple of things i have tried have been uninstalling the microsoft c++, deleting temp files, and editing the setup.ini to skip the check for it but it still checks for some reason
Hello and welcome to the forums.
To be sure that you have the complete content of 3ds Max 2014 installer locally on your system, please download your product installer using “Browser Download” method or via Autodesk virtual agent.
1.Go to http://www.autodesk.com
2.At the bottom of the page, beneath Help and Support, click Customer Service.
3.Click the Ask button.
4.In the Virtual Agent window, click Downloading and Installation.
5.Click Software Download links.
6.Click "I need to redownload my product."
7.Click on 3ds Max Products.
8.Select Autodesk 3ds Max 2014.
Then uninstall all installed Visual C++ redistributables from your system and try installing your product as follows:
1.Logon as an Administrator.
2.Empty your TEMP folder. To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
Note: If your product installation fails and you decide to open a Support Request with Autodesk Product Support, we would need to review install logs created in your TEMP folder during this product installation attempt.
3.Disable your Antivirus software.
4.Disable UAC.
http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
5.start installing 3ds Max 2014 from newly downloaded installer.
Hope this helps.
If it still checks, then you have not correctly modified the file. Try commenting out the entire PREREQUISTE line altogether then.
