• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Software License Check Out Failed Error 5
    488 Views, 6 Replies
    01-13-2013 01:47 AM
    I have been experiencing this problem since today i have got 3DS Max, yes i know i need to delete CascadeInfo.cas, but i haven't got it on my PC, running on Windows 8. I only see productinformation.pit and that's it.
    I haven't got any clue how to fix this.
    I hope you guys may be able to help me out..
    Greetings,
    Weecow
    Please use plain text.
    Member
    Re: Software License Check Out Failed Error 5
    01-14-2013 11:02 AM in reply to: Weecow
    So i bump this, as no one has responded, i really want to use this program..
    Sorry for bumping.
    *Expert Elite*
    TravisNave
    01-17-2013 09:10 AM in reply to: Weecow
    Have you tested all the connectivities to your license manager?  PING to verify IPv4?  Tested ports 2080 and 27000?  The CascadeInfo.cas file will not be created until it makes a valid connection.  I suspect firewall or IPv6 is the issue.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    01-17-2013 12:36 PM in reply to: TravisNave
    Hello, I really don'y know what you are talking about, what license manager? Greetings, Weecow.
    *Expert Elite*
    TravisNave
    01-17-2013 12:43 PM in reply to: Weecow
    Then I assume you have the stand-alone activated license version?
    Travis Nave
    Product Support
    01-18-2013 12:38 PM in reply to: Weecow
    Weecow,
    Hello. Not sure why you would need to delete the cascadeinfo.cas file. So far, Cascaldeinfo.cas has nothing to do with your issue. And please do not delete your Pit file. I am guessing you are a standalone installation. We see this error occasionally with a standalone. If you are a network, this is totally different. If you don’t know if you are using a network seat, you need to talk to your IT manager. If you are just a one man shop- likely standalone.
    You need to uninstall and reinstall. I have a process for you. First, uninstall the program through the Control Panel.
    After this, run the MS Fixit uninstaller and see if the product still lists. If it does, uninstall it.
    http://support.microsoft.com/mats/Program_Install_and_Uninstall\
    Next, delete the MAX program folders in these locations (they should be clearly named).
    C:\Program Files\Autodesk\
    C:\ProgramData\Autodesk\
    C:\Program Files (x86)\Autodesk\
    C:\Users\All Users\Autodesk\
    C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
    C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
    After these are deleted, I would reinstall as an admin with UAC and antivirus turned off.
    Thank you for taking part in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
    Member
    01-21-2013 11:51 AM in reply to: dembkod
    Hello, I'm really sorry, but this hasn't helped me, i still got the same error as before.. I hope you can still help me further, because i have no idea what to do next. Greetings, Weecow
