Installation & Licensing
Software License Check Out Failed Error 5
18 REPLIES 18
Message 1 of 19
Weecow
17257 Views, 18 Replies
I have been experiencing this problem since today i have got 3DS Max, yes i know i need to delete CascadeInfo.cas, but i haven't got it on my PC, running on Windows 8. I only see productinformation.pit and that's it.
I haven't got any clue how to fix this.
I hope you guys may be able to help me out..
Greetings,
Weecow
18 REPLIES 18
Message 2 of 19
Weecow
in reply to: Weecow
So i bump this, as no one has responded, i really want to use this program..
Sorry for bumping.
Message 3 of 19
TravisNave
in reply to: Weecow
Have you tested all the connectivities to your license manager?  PING to verify IPv4?  Tested ports 2080 and 27000?  The CascadeInfo.cas file will not be created until it makes a valid connection.  I suspect firewall or IPv6 is the issue.
Autodesk Forums:
Message 4 of 19
Weecow
in reply to: TravisNave
Hello, I really don'y know what you are talking about, what license manager? Greetings, Weecow.
Message 5 of 19
TravisNave
in reply to: Weecow
Then I assume you have the stand-alone activated license version?
Autodesk Forums:
Message 6 of 19
dembkod
in reply to: Weecow
Weecow,
Hello. Not sure why you would need to delete the cascadeinfo.cas file. So far, Cascaldeinfo.cas has nothing to do with your issue. And please do not delete your Pit file. I am guessing you are a standalone installation. We see this error occasionally with a standalone. If you are a network, this is totally different. If you don’t know if you are using a network seat, you need to talk to your IT manager. If you are just a one man shop- likely standalone.
You need to uninstall and reinstall. I have a process for you. First, uninstall the program through the Control Panel.
After this, run the MS Fixit uninstaller and see if the product still lists. If it does, uninstall it.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Next, delete the MAX program folders in these locations (they should be clearly named).
C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Program Files (x86)\Autodesk\
C:\Users\All Users\Autodesk\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
After these are deleted, I would reinstall as an admin with UAC and antivirus turned off.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Message 7 of 19
Weecow
in reply to: dembkod
Hello, I'm really sorry, but this hasn't helped me, i still got the same error as before.. I hope you can still help me further, because i have no idea what to do next. Greetings, Weecow
Message 8 of 19
godogs2002-1
in reply to: Weecow
Why cant  anyone answer this question  with a good answer WINDOWS 8   I  GET A ERROR 5   FOR THE LAST  6 MONTHS .  I AM THINKING  THIS IS A BUNCH   OF  BULL **** WHERE  IS THE  FIX  FOR THE SOFTWEARE  SO NOW I AM   SUPPOST TO  QUIT SCHOOL, STOP WORK  WITH THIS PROGRAM IS THE ONLY WAY TO FIX IT  I GUESS.  FIX THE GOD **** THING  ALL READY
Message 9 of 19
TravisNave
in reply to: godogs2002-1
Relax.  This is a professional community forum.
Please list what software version you are using.
Autodesk Forums:
Message 10 of 19
n4nature
in reply to: Weecow
I have been trying to install Autodesk 3ds Max 2014 on Windows 8 and hitting this error:
Examining file at AppData\Local\Autodesk\3dsMax\2014 - 64bit\ENU\MAXENT_2014_en-US_adlm.txt shows logs as below:
3456 2013/08/13 10:26:37 Reason=Fatal error
3456 2013/08/13 10:26:37 OS=6.2.9200.
3456 2013/08/13 10:26:37 File=AdlmIntSATSLicense.cpp,Line=344
3456 2013/08/13 10:26:37 AdlmIntError=5 [Unable to launch or connect to LMU]
Anybody knows how to connect to LMU? Is there an AutoDesk service pack available for this issue?
Here's the stack trace for the app crash.
APP:  lmu.exe
FAULTING_THREAD:  0000000000000003
PRIMARY_PROBLEM_CLASS:  STATUS_BREAKPOINT
BUGCHECK_STR:  APPLICATION_FAULT_STATUS_BREAKPOINT
LAST_CONTROL_TRANSFER:  from 00007ffefaab9bb5 to 00007ffefaab2e5c
STACK_TEXT:
00000000`00d9e880 00007ffe`faab9bb5 : 00007ffe`fc21fff4 00000000`00000000 00000000`02ba7160 00007fff`187b0000 : adlmact_libFNP+0x3f2e5c
00000000`00d9e8b0 00007ffe`faaba00f : 00000000`cc4f4e80 00000000`00d9ed70 00000000`00d9ed70 00000000`00d9eca0 : adlmact_libFNP+0x3f9bb5
00000000`00d9e970 00007ffe`faaba324 : 00000000`cc4f4e83 00000000`00d9ed70 00000000`00d9ed70 00000000`00d9eca0 : adlmact_libFNP+0x3fa00f
00000000`00d9ea40 00007ffe`faaba634 : 00000000`cc4f4e82 00000000`cc4f4e82 00000000`00d9ed70 00000000`00d9eca0 : adlmact_libFNP+0x3fa324
00000000`00d9eb00 00007ffe`faaba920 : 00000000`cc4f4e85 00000000`00d9ed70 00000000`00d9ed70 00000000`00d9eca0 : adlmact_libFNP+0x3fa634
00000000`00d9ebc0 00007ffe`faabaaf4 : 00000000`00d9ed70 00007ffe`fac5cbe8 00000000`00d9ed70 00007ffe`fac5cbe8 : adlmact_libFNP+0x3fa920
00000000`00d9ec80 00007ffe`faabac8b : 00000000`00000000 00000000`00d9f6d0 00000000`00e723b0 00000000`00e723b0 : adlmact_libFNP+0x3faaf4
00000000`00d9ed40 00007ffe`fc00239f : 00000000`00000002 00007ffe`faababb0 00000000`00d9f6d0 00000000`0000000a : adlmact_libFNP+0x3fac8b
00000000`00d9eec0 00007ffe`fc042f84 : 00000000`029428a8 00007ffe`fbf73b81 00000000`00d9f050 00000000`00d9ef78 : adlmact!adlmActAppModifyLicenseTerms+0x9ed89
00000000`00d9eef0 00007ffe`fbfb270b : 00000000`00000000 00000000`0294b890 00000000`0294b890 00000000`0294b928 : adlmact!adlmActAppModifyLicenseTerms+0xdf96e
00000000`00d9ef30 00007ffe`fbf6e2bc : 00000000`02942880 00000000`00d9f050 00000000`00d9f040 00000000`00d9f000 : adlmact!adlmActAppModifyLicenseTerms+0x4f0f5
00000000`00d9f000 00007ffe`fbf66098 : 00000000`0294dbd0 00000000`00000002 00000000`02942880 00007fff`191ece88 : adlmact!adlmActAppModifyLicenseTerms+0xaca6
00000000`00d9f080 00007ffe`fc25239e : 00000000`68cc4280 00000000`028ada30 00000000`028bbc30 00000000`68cc3c9f : adlmact!adlmActAppModifyLicenseTerms+0x2a82
00000000`00d9f3d0 00007ffe`fc2537be : 00000000`00d9f5e0 00000000`00d9f670 00000000`028b51d0 00000000`00000001 : lmumain+0x239e
00000000`00d9f560 00007ff6`2f1c10b8 : 00000000`00d9f5d0 00000000`00d9f670 00000000`028b51d0 00000000`00000001 : lmumain+0x37be
00000000`00d9f5b0 00007ff6`2f1c1f53 : 00000000`00000002 00000000`028b51d0 00000000`0000000a 00007ff6`2f1c473c : LMU+0x10b8
00000000`00d9f670 00007ff6`2f1c15cb : 00000000`00e62b08 00000000`00000000 00000000`00000000 00000000`00000000 : LMU+0x1f53
00000000`00d9f6f0 00007fff`187b1641 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : LMU+0x15cb
00000000`00d9f7a0 00007fff`1abf52f9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : KERNEL32!BaseThreadInitThunk+0xd
00000000`00d9f7d0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x1d
STACK_COMMAND:  .cxr 0x0 ; kb
FOLLOWUP_IP:
adlmact_libFNP+3f2e5c
0033:00007ffe`faab2e5c cc              int     3
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  adlmact_libfnp+3f2e5c
Thanks!
NT
Message 11 of 19
godogs2002-1
in reply to: Weecow
So your telling me you have no fix for a error 5 that autodesk has made  for conection issues to activate the software.  And you have no support technions  to address  how to disable IV6  so that  just   the IV4 conects to base servers?  Sounds like you  need to find away to have a patch that can fix the reg of a computer  in  a remote seting. where can i get the old software that worked correctly with out  a  error. you can tell me you  have not fixed  this for someone  before.   Myt issue is this it installes correctly    just the actvation fails  because of your internet valdation can  make a conection.   even though its been installed  from  internet  you need  a  hotfix to patch this!!
Message 12 of 19
TravisNave
in reply to: n4nature
Thanks!
NT
Welcome to the community.
Check to see if the 2014 Activation crash is applicable to your issue.
Also, add the application to your firewall exceptions or as a trusted application.  Error 5 is sometimes a blocking error.
Autodesk Forums:
Message 13 of 19
TravisNave
@godogs2002-1 wrote:
So your telling me you have no fix for a error 5 ... And you have no support technions ...?  Sounds like you  need to find away to have a patch that can fix the reg of a computer  in  a remote seting.
This is a peer community.  I am not Autodesk.  There is no 'proverbial' you here.  This is a forum of users helping users.
Autodesk Forums:
Message 14 of 19
soomro.sohail
Hello Sir,
My name is Sohail Soomro
I am Experiencing the same problem from couple a days, i have tried to reinstalling but doesn't works,
Kindly tell me what should i do, i have a lot work to do, stuck in problem,
soomro.sohail@outlook.com
Message 15 of 19
@soomro.sohail
Welcome to the community..
This posting that you replied to is 3 years old.  "Experiencing the same problem"  Can you give us more details?  I don't want to assume that you are using the same Autodesk product and version as the original poster had.  What type of license is it?
Mark Lancaster
Message 16 of 19
shakirkarukamadu
in reply to: Weecow
I got license checked out problem in my 3ds max.
And I deleted my 3ds max all files and reinstall that but never got this problem.
now I have many projects
So please help me.
Message 17 of 19
shakirkarukamadu
in reply to: Weecow
Ds max 2014
64 bit
Message 18 of 19
fareeha315
Someone please tell me that deleting these autodesk folders would effect my other autodesk softwares installed on computer or not. (other sodtware like autodesk revit or autocad).
Message 19 of 19
mdavis22569
in reply to: Weecow
@fareeha315
Which Autodesk folder?  This is a 10 year old post .. a lot has changed
Mike Davis
Administrator Productivity
