Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Software License Check Out Failed Error 5
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have been experiencing this problem since today i have got 3DS Max, yes i know i need to delete CascadeInfo.cas, but i haven't got it on my PC, running on Windows 8. I only see productinformation.pit and that's it.
I haven't got any clue how to fix this.
I hope you guys may be able to help me out..
Greetings,
Weecow
Re: Software License Check Out Failed Error 5
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So i bump this, as no one has responded, i really want to use this program..
Sorry for bumping.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tested all the connectivities to your license manager? PING to verify IPv4? Tested ports 2080 and 27000? The CascadeInfo.cas file will not be created until it makes a valid connection. I suspect firewall or IPv6 is the issue.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Software License Check Out Failed Error 5
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Then I assume you have the stand-alone activated license version?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Weecow,
Hello. Not sure why you would need to delete the cascadeinfo.cas file. So far, Cascaldeinfo.cas has nothing to do with your issue. And please do not delete your Pit file. I am guessing you are a standalone installation. We see this error occasionally with a standalone. If you are a network, this is totally different. If you don’t know if you are using a network seat, you need to talk to your IT manager. If you are just a one man shop- likely standalone.
You need to uninstall and reinstall. I have a process for you. First, uninstall the program through the Control Panel.
After this, run the MS Fixit uninstaller and see if the product still lists. If it does, uninstall it.
http://support.microsoft.com/mats/Program_Install_
Next, delete the MAX program folders in these locations (they should be clearly named).
C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Program Files (x86)\Autodesk\
C:\Users\All Users\Autodesk\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
After these are deleted, I would reinstall as an admin with UAC and antivirus turned off.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
