Installation & Licensing
Softimage / Maya start-up failure_Entertainment Suite 2012
3 REPLIES 3
MisterMasters
327 Views, 3 Replies
I have installed the Creative Suite on an Administrator Desktop and planned to use a Standard desktop to run the programs and connect to internet for safety. On the administrator desktop, all programs except for Softimage 2012 startup fine. On the standard desktop it is the same as well as Maya 2012 not initializing and my having to log-off to leave the start-up window.
HP Compaq 8200 Elite
intel core i7-2600 cpu
3.40 ghz
12GB ram
Bit
nvidia Quadro 600 - driver version 8.17.12.7614
Zonealarm Extreme Security
Microsoft Security Essentials
As for Softimage, I have tested to see if it is the current nvidia drivers are the issue by changing the "Default.xsily" layout file in a text editor and had the same results.
With Maya 2012, I"m thinking it may be an "administrator privileges" log-in hang-up because it will launch on the "admin" desktop but not the "standard" desktop.
I have also called "Installation Support" listed on the back of package and the drivers are the only explanation I have been given. Any help is appreciated.
3 REPLIES 3
Do you have Digital Persona installed?
If that's not it, here's some startup troubleshooting topics from the Softimage KB:
http://usa.autodesk.com/adsk/servlet/ps/search?la=en&siteID=123112&catID=2334116&linkID=12544120&qt=...
// Stephen Blair
// Arnold Renderer Support
Hey, thanks for answering. No I don't have Digital Persona installed on this system. Additionally, It was the Softimage KB that lead me to modify the default layout to see if it was a driver issue. I also have found no answers for my Maya 2012 issue. In thinking it was an administrator desktop hang-up, I created a second admin desktop and still had no success with Maya starting up. At this point the only thing I can think of is an un-install/reinstall for both programs. Other than that I'm out of ideas.
OK, all fixed. Found Digital Persona was installed but not listed in the "program files" or "program files(x86) folders. I got this box from an HP refurbisher and he corrected the issues for me. Thought I was crazy for a while not knowing what the hang-up was. Thanks for the effort Stephen.Blair . Much appreciation.
Administrator Productivity
