Installation & Licensing
mku
New Member
Message 1 of 4 (749 Views)
Smoke Unable to start license server Mac OSX 10.8
749 Views, 3 Replies
04-24-2013 08:19 AM
I have a networked educational license for Smoke.  I have installed the License Server Configurator from the disk, but I cannot get it started.  I want to use a single server.
I have the correct host name (unless it is case sensitive). I used the mac address for my Ethernet adapter, however, when I run the  "/usr/local/flexnetserver/lmutil lmhostid -n" command, it returns a different value. In fact, it returns a mac address for hardware I cannot identify.
It's unclear to me even if I'm supposed to be using the License server configurator or the Network License manager.
When I download Autodesk IPv4 Network License Manager for Mac OS X, I don't get "lmgrd, adskflex, and lmutil." In fact, step 3 of the readme for this download (The NLM should be installed under /usr/local/flexnetserver) doesn't appear to be true.
I've attached a screen shot of my stopping point.  I dropped the license file in two locations: usr/adlm and /usr/local/flexnetserver/.
I can't tell what I'm missing, and the instructions are anything but clear. Can anyone provide insight on this?
Product Support
Robert.Adam
Message 2 of 4 (733 Views)
Re: Smoke Unable to start license server Mac OSX 10.8
04-24-2013 09:41 AM in reply to: mku
Hi.
Unfortunately that's a known issue with Mac OS 10.8 and it also affects other software products that use the FlexNet licensing framework.
When you restart your Mac, the OS may activate the network adapters in a different order, so the computer's host ID changes to the other card and the license server no longer recognizes it.
Here's a KB article with a few workarounds: http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21280818&linkID=9242618&siteID=123112
Robert.
Autodesk Flame and Smoke Customer Support
If my answer solved your issue, please click "Accept as Solution"
mku
New Member
Message 3 of 4 (711 Views)
04-24-2013 12:55 PM in reply to: Robert.Adam
That is a problem, however after many restarts I've never been able to get the license server to start ever, so I don't think I'm getting to the point you're speaking of, but I'll give it a look.
Product Support
Robert.Adam
Message 4 of 4 (681 Views)
04-25-2013 05:12 AM in reply to: mku
Hi.
Go into system preferences > Network and disable all network interfaces except the wired one that was originally used to generate your license key.
Then power off, unplug the cable for 10 seconds and power back on.
Another tip: after you run the un the "/usr/local/flexnetserver/lmutil lmhostid -n" command, also run the "ifconfig" command in the terminal and compare the "ether" values in the command output to the host ID value you got from the lmutil command. I'm sure it must match one of those entries. Possibly a network interface that's not listed in the system preferences panel, that's why you couldn't see it before.
Thanks!
Robert.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
